Tech / How To
Transmission issues..
Old Mar 25, 2013 | 09:25 AM
ucmj22's Avatar
ucmj22 is infamous around these parts
Having some issues with my transmission. I dont like taking my car in until I have a good Idea of what the problem is, so hopefully someone has heard of these symptoms before.
Vehicle: 2006 Cad CTS Manual
Symptoms:
1- Light scratching noise when fully engaged in 1st, 3rd, or 5th gear. driving down the road, I will hear a scratching noise. If I pull back on the stick, just a quarter inch, the noise goes away, and returns when I release. R, 2nd, 4th & 6th make no noise.
2- Flutter noise. Started as what I would describe as a fluttering noise when coasting with clutch depressed, or in neutral, slowing as speed reduces. more recently it has started to sound like like the showcase showdown wheel on the price is right, almost a clicking instead of a flutter.
clutch feels good, no problems moving in and out of gears, issues are only noticed when gear is fully engaged, or neutral.
Any ideas would be helpful, some have suggested synchro gears, others shift linkage, but I'm not sure. Thanks in advance.
Old Mar 25, 2013 | 12:55 PM
ucmj22's Avatar
any takers?
Old Jul 12, 2014 | 06:53 AM
sagenicola's Avatar
sagenicola is infamous around these parts
I think you should check out this place called http://www.iautobodyparts.com/guide_and_tips.html where you’ll get all the information about car parts. Few months ago when my car started giving me some trouble, I found this place on the internet while searching. This place helped me a lot fixing my car on own. So I’d suggest you to check out this place and learn car repair tips.
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
dr bit
Oct 12, 2015 09:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
alpha motoring
Oct 2, 2015 12:04 PM
panas001
Sep 27, 2015 02:51 PM
