Heat Cycling tires
Old Aug 30, 2008 | 12:35 PM
HWJunkie's Avatar
HWJunkie is infamous around these parts
Heat Cycling tires
Can someone tell me the advantage of getting the tires pre-heat cycled over just using them the way they come. Becuase if I use them at the track the first time, they are then heat cycled, aren't they?
Old Aug 30, 2008 | 12:49 PM
damon@tirerack's Avatar
Moderator
Please read this:
http://www.tirerack.com/tires/tirete....jsp?techid=66
It should answer all your questions. Please call me if it does not.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 30, 2008 | 01:23 PM
HWJunkie's Avatar
Originally Posted by damon@tirerack
Please read this:
Now I know...
Thanks for that, I appreciate it!
Old Aug 30, 2008 | 07:29 PM
HWJunkie's Avatar
So if I get a new set of tires and I take them in the canyons, come home and let them sit for 24-48 hours, is that considered a heat cycle or does it have to be a "track" heat cycle?
Old Sep 2, 2008 | 04:43 PM
Springgeyser's Avatar
Springgeyser is infamous around these parts
I heat cycled my Rcomps tires by driving on the freeway then resting them.
There is a link out there where a test was done on Heat Cycle for tires.
-Tire Rack heat cycle tire.
-Heat Cycle from street driving.
-No heat cycle.
The longevity on the Tire Rack and street heat cycle tire were the same. The tires that were not heat cycled
Old Sep 2, 2008 | 04:46 PM
Old Sep 9, 2008 | 07:40 PM
george3's Avatar
george3 is infamous around these partsgeorge3 is infamous around these parts
There are many opinions of heat cycling tires. Some say it definitely improves their life, other say just drive on them and they'll last just as long. I don't have enough experience to tell you which, but if you have the ability to heat cycle them for one 15 minute session and put them away for a few day... whatcha' got to lose ???
Old Oct 24, 2008 | 01:34 PM
Bleu Omdurman's Avatar
Bleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond repute
^^^ True
I'd also add, that you may or may not get them to heat up during a canyon run. The test is to come out of a turn and immediately take the temp of the tires. They should be about 170-190 degrees. If they are, then you got them "up to temp" and you can set them aside to cure. It is fine to drive home with them at that point. Assuming, "home" isn't a couple hundred miles.
just my opinion.
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
riverflyer
Sep 1, 2015 04:22 PM
Jaytaylor10485
Aug 28, 2015 06:25 AM
