track tires?
Old Jun 28, 2007 | 11:41 AM
  #31
|Drew|'s Avatar
|Drew| is infamous around these parts
Originally Posted by RonCT
Carful with the RA1s - just ran them on my 997s for the first time and boy are they pressure sensitive. Go just a few lbs over 40 and they let go without warning under power. Once dialed in, they were nice, but right now I still feel I like the PSCs better. I did not get mine shaved, and many at WGI said that was the trick -- but I wanted them unshaved to be the "everything" R-comp (wet, cold, dry).
I hear ya. Similarly, I have heard they're kinda wild in the dry at full depth. I think I'll ride around on them a bit before the first event.
Old Jun 29, 2007 | 12:46 PM
  #32
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
Ive had my best luck with the PCS...I run stock sizes as it doesnt upset the car at all and really...im not really losing much grip...I have run a variaty of cold start pressures and LIKE the fact that they require a lap or two of warm up...makes me (driver) warm up as well...
I just ran them at over 170 mph and they held the heat amazingly well for such a big *** car...I do feel like I can OVERHEAT most tires really quickly...
Old Jul 10, 2007 | 04:46 PM
  #33
B-moreBroker's Avatar
B-moreBroker is infamous around these parts
888's
Just ran on the 888's for the first time... I'd say 50% improvement over RA1 on dry conditions... definitely my favorite tire...
Old Jul 11, 2007 | 08:04 PM
  #34
HotRodGuy's Avatar
Originally Posted by |Drew|
NT-01s are on a huge backorder...ended up with a set of the Toyo RA1s. edgeracing.com had the best price I could find. I don't know why Discount Tire and Tire Rack don't carry Toyos yet...Discount was willing to offer me a huge discount for a bad experience trying to order the Nittos.
Toyo doesn't deal w/ nationwide distributers. They deal with smaller local distributers. It's been the toyo way since day one.
We let the Nitto's get slutted nation wide
Old Jul 11, 2007 | 08:05 PM
  #35
HotRodGuy's Avatar
broker, what are your thoughts about noise compared to the RA1? Are the 888's much louder?
Old Jul 12, 2007 | 07:24 AM
  #36
teutonictrio's Avatar
Banned for Eternity
teutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond repute
Anyone else hear of the new Hankook tire that is supposed to be a clone of the Hoosier R6?? I guess some of the Boxster Spec guys are planning to test them out - almost the same tire at $40 less per tire would be sweet.
Old Jul 12, 2007 | 07:52 AM
  #37
Grantsfo's Avatar
Grantsfo is infamous around these parts
Cant beat them for value. Several people including me are using them in local track and AX scene in Nor Cal with great results. I have a set of their new F200 radial race slicks. They are less than some DOT R tires on the market! Nice thing about Hankooks is variety of compounds they sell. From very soft to hard.
Z211 is treaded DOT R and Z214 is slick DOT R.
http://www.hankooktireusa.com/produc...20r%20compound
Old Jul 12, 2007 | 08:41 AM
  #38
Originally Posted by YSS
where can i get R888 or NT-01 in 19"
they show them as available sizes on the web site but i need a dealer
I got mine from Radial Tire in Silver Spring, MD.
(301) 585-2740 ask for Paul... I know they just got a bunch that fit 997s stock 19s....
Old Jul 12, 2007 | 08:42 AM
  #39
maybe a little noiser but I'll take it for the performance
Old Jul 12, 2007 | 10:32 AM
  #40
SxxB's Avatar
SxxB is infamous around these partsSxxB is infamous around these parts
I bought my R888 from...
Frisby Tire. Heard good things about them, and they were able to get me the tires while other dealer couln't even say when exactly r888 will be available.
Serge
Old Jul 14, 2007 | 04:10 PM
  #41
blackbenzz's Avatar
blackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of light
Guess its time to upgrade from the RA1's
Old Jul 14, 2007 | 04:56 PM
  #42
tires run hot!
just an FYI ... I have been experimenting with the r888 pressure and it seems like the ideal cold pressure is 28 (front) and 29 (rear). It took me 2 days on the track to find the right pressure because they heat up a lot! If you drive like I do you will be at 39/40 psi after a couple of trips around the track and you will feel like you are in a go-kart... The tires are so sticky and brought my times at least 2-3 seconds faster than the ra1's... make sure you get these tires!
Old Jul 16, 2007 | 04:55 AM
  #43
YSS's Avatar
YSS
YSS is infamous around these parts
thanks for the tip
i bought a set locally as they where in stock.
will get the first go at them soon and will post then
Old Jul 17, 2007 | 06:22 PM
  #44
Dub-U!'s Avatar
Dub-U! is infamous around these parts
With the PSC's, do they have heat cycle issues? Or can I wear them on the street to the track and back again?
Old Jul 17, 2007 | 08:06 PM
  #45
RonCT's Avatar
RonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond repute
No problem on the street to and from events - many of us do it on PSCs, RA1s, etc. You don't put enough heat into them on the street to have a negative impact. When I heat cycle (1st) a new set of tires on the street, I push them and go through a bedding in process to get the heat into them -- not something you'd ever normally do on the way to the track.
