Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Rating: Thread Rating: 90 votes, 4.16 average.
Old Oct 30, 2006 | 11:04 PM
  #2191
cjv's Avatar
cjv
Moderator
Originally Posted by Craigger
So...how many?
2 cases, 3 piston sets, 2 cranks, 3 sets of valves, 3 sets of springs, 2 sets of heads, 5 cam sets, 2 cam housings, 3 tappet sets and three sets of turbo's.
Old Oct 30, 2006 | 11:10 PM
  #2192
Phoenix's Avatar
Phoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant future
CJV,
What will KA be running in the brake department?
Old Oct 30, 2006 | 11:17 PM
  #2193
Craigger's Avatar
Craigger is infamous around these parts
I love you.
but really,
what are your estimates on rise in view/replys do you think this will jump to once the numbers video or anything (with your consent) are released?
Congratulations.
Old Oct 30, 2006 | 11:19 PM
  #2194
Craigger's Avatar
also, if i may ask what different turbos did you go through?
Old Oct 30, 2006 | 11:21 PM
  #2195
Alex's Avatar
Alex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant future
...and a aprtridge in a pear tree!
R & D is expensive as hell no doubt.
Old Oct 31, 2006 | 05:31 PM
  #2196
chidoks's Avatar
chidoks is a jewel in the roughchidoks is a jewel in the roughchidoks is a jewel in the roughchidoks is a jewel in the rough
its rare to find people as dedicated as you. are you going to put all your research into practice maybe my marketing an engine and transmission package based on your findings? or is this more of a personal venture?
chidoks,
There appear to be many different marque owners awaiting KA's completion. Most of the responses, like your's, have been very positive and encouraging. We gave up looking at the costs a long time ago. You would laugh (or cry) if you really knew how many cases, pistons, rods, cranks, valves, springs, heads, cams, cam housings, tappets, turbo's etc. we have ordered or custom made, modified and then discarded because we learned something new. We believe we have explored every nook and cranny of this motor.
We hope in the end, it will live up to our expectations.
Old Oct 31, 2006 | 07:07 PM
  #2197
cjv's Avatar
cjv
Moderator
It is a personal venture although S Car Go Racing, who has done most of the work has benefited from several of the parts that were developed.
Old Nov 1, 2006 | 10:14 PM
  #2198
cjv's Avatar
cjv
Moderator
Thanks to some friends in Germany, we will have these unique cam housings on November 6th. That is almost four weeks early. It appears the big boy in Germany is interested in seeing our work product completed.
Old Nov 3, 2006 | 01:54 AM
  #2199
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
as are we...looking good....
Old Nov 5, 2006 | 12:15 PM
  #2200
cjv's Avatar
cjv
Moderator
We have had many people ask us what what is involved in our cam project. Here is a brief description.
First we completed the GT3 R heads. Minor touch up of the ports and combustion chambers, ceramic coating and then micro polish of the coating in the combustion chambers. The heads were then flowed to determine optimum lift and duration for the intake and exhaust cams. Now on to the cams. Here is a short description.
Design radius bucket follower intake cam profile to replace factory turbo lift variable lift profile.
Design radius bucket follower exhaust cam profile to replace factory turbo flat profile.
Manufacture intake master plate.
Manufacture exhaust master plate.
Grind engine set of new factory blanks with above masters.
Measure radius of cam follower and CNC machine probe to measure street GT3 cams.
CNC machine drive fixtures to reference cam lobes to slot in rear of cam for factory cam timing tools.
Fit GT3 cam trays to GT3 R heads. Fit GT3 cams with GT3 buckets, measure valve lengths and bucket clearances.
Final fit of new design cams with trays and buckets. Check bucket clearances on base circle.
The time involved has been about eight months. The cost to flow, design, profile, and manufacture specific intake and exhaust cams was more than a regular engine rebuild. One thing we have learned is we will pick up approx. ten hp for every ten thousands of an inch we increase the lift up to a certain point. In addition, by custom sculpturing the duration for turbo application, the motor should be as smooth as silk with excellent response throughout the entire usable rpm range (2000 to 9200).
Old Nov 7, 2006 | 04:19 PM
  #2201
cjv's Avatar
cjv
Moderator
I know some of the 6speed members have upgraded their intercoolers. Has anyone used a certain heat dispersant coating on their upgrades?
Old Nov 7, 2006 | 04:51 PM
  #2202
KhanNSX's Avatar
KhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud ofKhanNSX has much to be proud of
That is a great question, I am working on a project as we speak that would benefit from this info as well.
BTW CJV, I have great patience, but you are showing a level of patience that is admirable. I am eager to see your final result(been following this thread for a very long time), and wish you best of luck.
Old Nov 7, 2006 | 05:25 PM
  #2203
sharkster's Avatar
I know some of the 6speed members have upgraded their intercoolers. Has anyone used a heat dispersant coating on their upgrades?
Now why would you want to do that I believe some company in Europe does that with their $16,000 cores
Old Nov 7, 2006 | 10:34 PM
  #2204
Chasen1211's Avatar
thats seems like chump change compared to how much it sounds like CJV spent on the whole project...
Old Nov 8, 2006 | 12:03 AM
  #2205
cjv's Avatar
cjv
Moderator
Chasen1211,
I believe Sharkster was poking fun at a certain IC manufacturer who charges about 16K for their IC's. Alot of money to say the least. We could never figure out until recently how they were about 10% more efficient than our custom IC's.
Well like years ago, when we figured out how Ruf's comparable motors always made a little more torque ............... we believe we have now figured out why these IC's were always about 10% more efficient. The cost to gain this additional 10% is less than $500.00. Of course you first have to start with a good metal core/tank IC. It won't be long before the cat is out of the bag.
Sharkster and I have shared alot of info throughout the years, he is aware of what we did.
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
