Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
  #2761
Old 06-06-2008, 09:20 PM
Phoenix's Avatar
Phoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant future
Chad,
Any updates? Thanks.
  #2762
Old 06-07-2008, 09:21 AM
cjv's Avatar
cjv
cjv is offline
Moderator
Updates:
Slow as usual. Let me explain what I believe is going on. Four years ago right before they were going to dyno the car, they bent all six rods. I had was going to do the internals anyway and had accumulated all the parts (less cams) they told me I needed and paid in advance for the labor.
To make a long story short, the job was more entailed than any of us imagined. I had to rebuy many parts over and they went through more labor than they anticipated. Thus, they are doing the work during times that other work is slow for them. I haven't really been making an issue with this as I undertsand the circumstances.
I guess the good news is I have been told they will get on it this month. We have decided to change the stock size 10 mm EVO head studs to 11 mm studs. This will require boring out the old holes and retapping one mm larger ones. It really isn't much of a change.
This is why I have not had much to report since April 26th. All parts both internal and external are ready for assembly.
  #2763
Old 06-08-2008, 07:36 PM
Phoenix's Avatar
Thank you.
As always, all the best.
  #2764
Old 06-08-2008, 07:39 PM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
You have much more patience than I do, nothing to do with a car is worth any of this
Christian
  #2765
Old 06-13-2008, 09:09 PM
cjv's Avatar
cjv
cjv is offline
Moderator
This is what we have decided to add as detailed by Performance Developments. Due to the o-ringing of heads and liners along with our own designed head gasket we needed to do something different with the head studs to keep the heads from moving at 2.4 bar.
Chad,
The following are the costs to do the work required to run the 12.00 mm Heads Studs.
Disassemble the heads. $120.00
Set up case halves, indicate all threaded holes and bore threaded holes larger . $360.00
Tap all bores for 12.00 mm 4h threads. $300.00
Set up Manifoldsand indicate all holes and bore for larger studs. $300.00
Set up Cylinder heads, indicate all holes and bore for larger studs, Counter bore for stepped washers. $576.00
Clean heads. $60.00
Assemble heads. $180.00
12.00 mm Head Stud kit with stepped head washers. $1,692.00
This work can be started immediately. The Stud kits are one week away.
These studs are anchored into the case with larger and courser threads, allowing the greater tensile to be added without stretching the threads in the Case. The stepped washers stop the head from collapsing inward around the stud. Any movement either with the stud or the head will decrease the tensile loading and not put the same amount of clamping force evenly on the head gasket.
Neil
(thanks for the info M42racer)
  #2766
Old 07-02-2008, 10:59 AM
chidoks's Avatar
chidoks is a jewel in the roughchidoks is a jewel in the roughchidoks is a jewel in the roughchidoks is a jewel in the rough
updates?
  #2767
Old 07-03-2008, 09:03 AM
CLS's Avatar
CLS
CLS is offline
CLS is infamous around these partsCLS is infamous around these parts
So Chad when do you think the motor will be put into the car and the tuning starts!
  #2768
Old 07-05-2008, 08:17 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Our 12 mm head studs just arrived.
  #2769
Old 07-05-2008, 08:21 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Craig ..........with the 12 mm head studs we now have all the parts. Heck, I can't think of an original Porsche part in this motor. Rob could do it in two weeks if he gave it his undivided attention, but we all know that won't happen.
  #2770
Old 08-12-2008, 08:01 AM
KompressorKev's Avatar
KompressorKev is infamous around these parts
any updates? i love reading about this project!
  #2771
Old 08-12-2008, 11:16 AM
Zippy's Avatar
Chad. It's time to get the check book out and get the boys working a little faster!
  #2772
Old 08-12-2008, 01:15 PM
Phoenix's Avatar
Chad, hope things are progressing smoothly?
  #2773
Old 08-22-2008, 09:19 PM
cjv's Avatar
cjv
cjv is offline
Moderator
The motor is being assembled at S Car Go. Waiting for some external motor parts from Protomotive. They shouldn't be much longer. S Car Go will also be installing a full roll cage. Then it will be off to ERP for some additional suspension and wide body work.
  #2774
Old 08-24-2008, 04:38 PM
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
This is GREAT news Chad!!! You can almost see home plate!!! Hope everything goes smoothly.
  #2775
Old 08-24-2008, 06:01 PM
Phoenix's Avatar
Will the roll cage be built in/hidden a la Ruf's integrated roll cage? Thanks.
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
Quick Reply: KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
