Wheels/Tires
The H&R Wheel Spacer thread - 996/997
Old Apr 11, 2009 | 03:54 PM
  #31
GT650-25's Avatar
GT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant future
Where can I buy 5mm spacers...are they worth it? do I need new bolts?
Is it different from 7 mm....?
I am running HRE P40 Mono and want it to come out a bit on the front wheel, its too tucked in...any suggestions on how much of a spacer etc...
Old Apr 13, 2009 | 12:57 PM
  #32
peter_bigblock's Avatar
peter_bigblock is infamous around these parts
Originally Posted by p0rsch3
jmla- Running spacers will not affect anything, it is more for looks to "fill out" the wheelwells. The only issue you can encounter is if you space the wheels out too far and rub fender...
I don't think that's exactly accurate. Moving the wheels further outboard will increase the scrub radius (make it more positive). I believe that can make the car easier to steer at low (parking lot) speeds. It can make the steering more sensitive to braking inputs and put some additional strain on hubs, half-shafts, and steering gear. Small increases to track width (10-20mm total) not so much, but I think when you start talking over 20mm you can alter the interplay between handling, steering, and braking, not necessarily for the better. You might research more before aggressively increasing the car's track.
Old Apr 17, 2009 | 05:03 PM
  #33
Bara's Avatar
Bara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant future
how do you explain Porsche using 17mm spacers on select 997 C4 and C4S from the factory?
Old Apr 19, 2009 | 11:13 AM
  #34
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Explaination.....I would say.....save cost, short cut, afterthought, ran out of time, nobody's perfect......
Anyway...I assume you mean something like ther past Carrera Sport Wheel.
Porsche AG marketed the wheel in this fashion rather than invest time or money in requiring the supplier produce a lower offset wheel for C4 and Targas.
No longer the case....ie C SIIs.
Old Apr 24, 2009 | 08:56 AM
  #35
damon@tirerack's Avatar
Moderator
Probably to save part numbers during vehicle production. Same spindles, joints, etc....
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Apr 27, 2009 | 05:45 PM
  #36
Bara's Avatar
do the H&R longer bolts have the ball washers just like the factory bolts where they wont eat into the the wheel when tightening?
do you have a pic to show us? thanks
Old Apr 27, 2009 | 06:49 PM
  #37
Bara's Avatar
Originally Posted by Alan Baylis
Yes, the H&R bolts have the rotating seat like the Porsche factory bolts.
thanks. so, who has the best price for a pair of 15mm with bolts?
Old May 6, 2009 | 05:17 PM
  #38
Moderator
$96 a pair, floating ball seat bolts $6each. In stock.
damon@tirerack.com
Or use this link:
Old Feb 26, 2011 | 07:50 PM
  #39
darmawaa's Avatar
darmawaa is infamous around these partsdarmawaa is infamous around these parts
What is the max spacer thickness without scrubbing the fender for stock 997.1 TT stock wheels, lowered 1" ?
What is the stock bolt length?
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
