Wheels/Tires
The H&R Wheel Spacer thread - 996/997
Old Aug 9, 2007 | 12:51 PM
damon@tirerack's Avatar
Moderator
I've had several inquiries, so here's what I have from H&R:
Hubcentric.
14957161, 7mm = $65 a pair
1455206, extended lugbolt= $6 each
30957161
, 15mm - $96 a pair
1456006, extended lugbolt $6 each
36957161, 18mm Cost $104.00 a pair
1456306, extended lugbolt $6 each
Available by special order:
46957161, 23mm Cost $130.00 a pair
1456806, extended lugbolt $6 each
In stock the best I can keep them. IF YOU ADD SPACERS, YOU MUST HAVE LONGER BOLTS.
Give me a call if interested, these are not available through our website. Of course, you assume all fitment issues if using these..
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Last edited by damon@tirerack; Sep 22, 2010 at 04:16 PM. Reason: 2010 Price updates
Old Aug 21, 2007 | 12:48 PM
CWtwin's Avatar
CWtwin is a jewel in the roughCWtwin is a jewel in the roughCWtwin is a jewel in the rough
I just got the spacers. Forgot to order the bolts seperate. What length do you recomend?
Old Aug 21, 2007 | 01:05 PM
Moderator
All I have is part numbers so I'm not sure the hardware specifics. Call/PM me with your spacer widths and I'll get you what you need.
damon@tirerack.com
Or use this link:
Old Aug 21, 2007 | 02:41 PM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
7mm require a 50/51mm Removable Ball Seat Bolt
15mm requires a 60/62mm Removal Ball Seat Bolt
Old Jan 5, 2008 | 08:16 PM
Mister PINK's Avatar
Mister PINK is infamous around these parts
Damon-
I have 20" techarts.. your suggestion? its a 997S NOT a turbo.
thanks.
Old Jan 6, 2008 | 02:42 AM
20C4S's Avatar
Originally Posted by Mister PINK
Damon-
thanks.
if u have aftermarket wheel chances are u don't need to add spacer since the offsets are already more aggressive. in ur case Techart wheels are already aggressive enough for the car imo.
Old Jun 7, 2008 | 04:09 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
how much total pm me and how to buy them !
Old Jun 14, 2008 | 05:14 PM
coolwater3's Avatar
coolwater3 is infamous around these parts
i dont know anythig about cars....but i just got a 2008 c2s and i want to put the rims from the Turbo on my car? what do i need to do? i see some wheels that came off of a trubo on ebay for about 3500...do i need any spacers or what? or maybe i need smaller tires for these rims? thansk
Old Aug 2, 2008 | 02:13 PM
mb5000's Avatar
mb5000 is just really nicemb5000 is just really nicemb5000 is just really nicemb5000 is just really nice
OP: Check your PM
Old Aug 13, 2008 | 06:42 AM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
Hey- why don't we have a NB thread?
I have 15mm R and 7mm F H&R spacers, and still have room to bring wheels out (OEM S wheels w/ 67 offset). Will the H&R 23mm spacers fit the rear, and 15mm on front? anyone tried it?
I'm positive that 20mm spacers will fit the rear given the room left with the 15mm's installed, but I do not see any 20mm spacers listed. Goal is to bring the wheels out flush with fenders. Did this on my 996 and used 15mm HR spacers on F/R, perfect.
Old Aug 20, 2008 | 06:32 PM
p0rsch3's Avatar
Damon any info on the spacer fit for 997? Perhaps I'll just go with 18mm on rear (15mm now)- would like to bring fronts out a bit more but I don't see anything other than 7mm or 14mm. I have the 7mm's on presently.
Old Aug 21, 2008 | 09:58 AM
nyc997cab's Avatar
nyc997cab is infamous around these parts
Hi Guys, What is the downside if any for spacers? Thanks.
Old Sep 18, 2008 | 12:30 AM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
I'd like to get a 7mm set with bolts.
Can you PM or email me? I'm too new to PM you.
Cheers
Aaron
Old Sep 24, 2008 | 08:21 AM
Jorgeassoc's Avatar
Jorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant future
I need spacers in the rear for my M5, but im currently running 295's, how much wider can i go? My car is not lowered.
Old Sep 27, 2008 | 03:37 AM
1JDM996's Avatar
1JDM996 has a spectacular aura about1JDM996 has a spectacular aura about1JDM996 has a spectacular aura about
how long is the wait for special orders?
