My Performance Upgrade Agenda / Questions
After a lengthy wait, I am taking delivery of my 2015 911 turbo s next tuesday and i am planning for some basic performance upgrades and hope you can chime in. Thanks.
Exhaust - I will choose a valve controlled exhaust ie Capristo, Techart, IPE. Probably leaning capristo especially after seeing the clip from another member here.
Headers - Not sure if I should swap it now or later.
Software Tune - I always thought I would go GIAC when i take possession, but as I am reading through the forum and comparing which is a better fit, FVD also popped out. Long term reliability and retaining the porsche warranty is a major factor for me to consider, and apparently FVD tune is not easily detected by dealership. Which would you choose if you have to pick one and why?
Filter - BMC
Springs - H&R or KW HLS2. The latter is obviously a lift system and cannot really compare to swapping out the springs. But for those who had thought about the lift system, why did you go ahead or shy away from it? Care to comment on this please. I am having second thought on KW because the set is quite pricey.
Filter - BMC
Exhaust and headers: I can't vouch for this personally but the rumor around here is that your car will negatively adapt to the exhaust without a tune. You will get an initial performance increase but the ECU will detect the change and de-tune to get back to stock power level. I'm a bit skeptical about this as I think that it's actually the owner adapting to the increased power and not noticing it as much over time. Who knows.
Software tune: I would personally go with GIAC but you should base the decision on your particular needs. You can't really "uninstall" the GIAC but you can flash it back to stock. Not necessarily the exact stock file that came on the car but more like back to stock power level. The dealer would have to make a deliberate effort to sniff out the change. See the discussion here https://www.6speedonline.com/forums/...-concerns.html
Filter: Why not?!
Can't comment on the springs. I will not be lowering my car since the southwest seems to be overpopulated with kamikaze rabbits that like to leap out in the road. I'm not convinced that a lowered car would even clear a dead one with the front lip extended. It's not worth the risk for me.
- Patrick
Filter: Why not?!
- Patrick
Congrats on the car!
So basically on my 991 Turbo S, I did not go with the TechArt Exhaust as it was not available at the time however it now is. We recently installed one and the sound was absolutely amazing. The Capristo sounds great as well however it is very raw, the TechArt seems much more refined. Also, the valved unit is much cleaner and uses the OEM Button in the cabin while the Capristo uses a wireless remote. I prefer the cleanliness of the TechArt button.
Regarding the KW HLS2 - I installed basically the same setup but the TechArt Variant (made by KW) and honestly the best mod I have ever done. The button for the noselift is cleanly put into the cigarette lighter. The 991 Turbo being as low as it is (even with the front spoiler retracted) the Noselift gave me the piece of mind that i wont be bottoming that out and having to replace a $2000+ spoiler (from what I am told at the dealer since for some reason mine blew right after taking delivery in stock form - compressor did not shut off and kept pumping air into the front spoiler and blew it - but thats another story hahaha).
Now I will say that I have done a ton of cars on the H&R's and the TechArt springs, so if you are comfortable with having to be a bit more careful, then go that route and save the money, if not - go with the noselift setup.
If you have ANY questions at all - please dont hesitate to ask. I will be posting a video of the TechArt exhaust in a few weeks when another client comes in for his build
Thanks for the feedback. If possible, can you post a sound clip of the tech art exhaust, I do like the clean install with the tech art as I believe you can wire it in to the sport plus button instead of a separate remote control.
As for the capristo exhaust, when valve is opened the rawness of the exhaust flow is quite intoxicated as well.
Here is a clip of the 991 Turbo S, with TechArt Powerkit & Exhaust
Give us a ring, or shoot me a PM for more information!
i have no experience with TechArt. I know their name and reputation seems solid. I have installed the tubi catless system that was way to obnoxiously loud and then went to euripipe and i am thrilled with their product. its perfect to me in every way. 100 sport cell cats and at idle slightly more aggressive and decel pops very melodic not like a fire*******. exhaust A+ in my opinion
IPD plenum no question best bang for the buck
GIAC has been a pleasure to work with and just forwarded to my local vendor the stage 2 file free of charge as a paying stage 1 customer.
car seems VERY fast. I really need to do some numbers at the track. I can say that my car on race fuel stage 1 going 55 on the x-way jason verlander hit it in his aventador speedster,his wing went up i then mashed my throttle and had to change lanes or I would have rammed up his butt....same mods using race fuel and giac stage 1 race program. Today i installed the stage 2 software good for 30-50 hp/tp more in race mode and its my more agile nimble and responsive. i will be getting on it tomorrow for more impressions.
bmc filter yup nice filter
Jeff, thanks for the feedback. Have you done a dyno on how much hp / torque based on your current set up. Seems like your current setup is very similar to my want to do mods.
Now the car only 24 km and i am pondering if i should do the mods after break in at 3000km or not. Based on my current schedule it would be 4 - 5 months from breaking in.
you might enjoy this exhaust.
The AWE Tuning Porsche 991 Turbo and Turbo S performance Exhaust System.
The only required upgrade with stage 2 is a turbo back exhaust system with high flow cats (or test pipes).
04-28-2022 12:38 AM
ECS Tuning - VW
08-21-2015 09:11 AM
ECS Tuning - VW
08-20-2015 02:01 PM
