Europipe SLEEPER!
Europipe SLEEPER!
I just went to my dealer and had the WE64 and WE66 campaigns done at same time as they installed my europipe.
When I started it up I instantly heard a better tone to exhaust although throughout rpm range I do not hear much difference in cabin, unless I go under a overpass and hear the turbo whistle.
Is this normal? This exhaust is perfect for a sleeper car, but I wanted a little more growl. Does it break in and get louder?
I didn't want an exhaust to wake neighbors, but this sounds a little mellow.
Any help is appreciated.
There is something wrong...The Europipe should be noticeably different. You should hear a lot more character, pops and gurgles, turbo whistle etc. Have you driven the car for 20 minutes or so to heat the cats up? Once they are hot I can't imagine you even posting a concern here. I'd check it out with your dealer or contact Stef.
Under full load the car is much more aggressive than stock and also I did not notice a change with break in.
I am driving around in sport mode and feel it sounds like stock. When I put it in sports plus it sounds absolutely AMAZING!
Wish there was a setting in the middle. Don't like redlining it every gear all the time.
Also, is it true that keeping revs high often shortens life of motor and components?
I can't speak for the Europipe exhaust ( although it's probably what I will get myself ), but in all my previous aftermarket exhausts ( mainly Akrapovic ), it can take several hundred km's for the exhaust to 'carbon' up and really develop it's true sound.
Give it a few weeks and see if it makes a difference.
Cheers,
Scar
Cheers,
Scar
Campaign WE64 will make the car sound significantly quieter, nothing I can do about that. You should ask your dealer but I doubt that such campaigns are reversible.
Take a look at the complains after the WE64 campaign:
https://www.6speedonline.com/forums/...aign-we64.html
https://www.6speedonline.com/forums/...campaigns.html
Sport plus sounds great but I suggest that you shift gears at the paddles as redlining for no reason is silly.
Same thing in sport mode: shift gears while under load and it’ll sound pretty loud. The more aggressive you drive the more aggressive it sounds. So don’t expect it to sound loud while strutting along at 1700 rpm or so.
Finally got to drive her again last night. Around town in normal and sport. It sounds like a minivan. When you put it in sports plus.... It wakes exhaust up and sounds like a tornado screaming down the street.
Perfect for a sleeper car. Not Reccomended for someone who just wants excessive noise and drone. EP does neither. Bc this exhaust is quite until you hit 3-4k rpms. After 5k it's a symphony!
Love, love, love it.
Glad you like it. I knew you would. I actually like the cabin quiet.
I drive in Sport all the time, and I can definitely hear the difference compared to normal. Definitely burbles on downshift without having to be in Sport Plus.
calbobba996TT
11-29-2015 03:29 AM
speedsterr
10-26-2015 09:18 AM
sdg1871
10-05-2015 07:05 AM
sdg1871
09-29-2015 09:30 AM
