Notices
911 1964- to current Porsche 911, from the air-cooled days to the current 997
Battery maintenance
Old Aug 17, 2018 | 09:27 AM
Markhurwitz's Avatar
Markhurwitz is infamous around these parts
Battery maintenance
I have a 1971 911E. What is the best way to keep the batteries maintained while leaving them in the car. Currently I put a trickle charger on the driver side battery and connect jumper cables to the Rt side battery. My charger has quit so I need to buy a new one. My question: How strong of a trickle charger do I need and am I hooking it up correctly?
Old Feb 28, 2020 | 12:59 PM
RGB81's Avatar
RGB81 is infamous around these parts
Any 12v 1.2 amp one should do it if you are only looking to condition and maintain.
Check out what Battery Tender has to offer.
Old Jul 27, 2021 | 06:16 AM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
I had mine on a trickle charger and after about a month or so when I switched the car on, Boom, the battery exploded and white smoke poured from the trunk. I had the trunk cracked and the light unplugged so that might have help when the battery blew. .Knew what happened and grabbed my fire extinguisher, some rags and baking soda from the garage fridge. But when I opened the trunk and the smoke cleared the explosion seemed confined by the carpet over the battery and no acid was sprayed in the trunk. Went out and bought a new battery and hooked it up and all was fine. I am no longer going to put any of my cars a charger and just start them out ever week or so.
CMartin348
May 3, 2011 10:41 AM
Sarum87
Apr 25, 2011 04:41 PM
Diamond Monaco
928
Feb 11, 2011 06:27 AM
jcramair1
Sep 22, 2003 03:13 PM
