Notices
911 1964- to current Porsche 911, from the air-cooled days to the current 997
Tech ?, door stay
Old Mar 22, 2007 | 05:07 PM
GarnetRedCoupe's Avatar
GarnetRedCoupe is infamous around these parts
Tech ?, door stay
I am in the process of replacing the door stays and adding the reinforcement kit to my ‘85 911. After I removed all of the trim pieces my next step is to remove the small “pin” that holds the door to the chassis.
Here is my problem: When I tap on the pin, either from the top or bottom, it doesn’t move, the only thing moving is the arm itself. I believe that the pin is rusted/frozen to the arm keeping it from coming out. I am afraid if I keep hitting it I could bust the weld on the door or bend the tab. Thoughts, suggestions…help!
Old Mar 22, 2007 | 08:09 PM
Just incase someone else needs help...I got some help from my local guys:
http://www.dorkiphus.net/porsche/showthread.php?t=13099
Old Mar 22, 2007 | 08:18 PM
flatsixnut's Avatar
flatsixnut is infamous around these parts
Does that mean that you got it off ok?
Ok I see from that link that you got quick help. I can always find quick help on everything 911 over at Rennlist or PelicanParts. It would be nice to get this forum alittle more active.
Old Mar 22, 2007 | 08:48 PM
I usually head to Pelican or my local forum for fast answers, I agree I would love to see our section a bit more active on the tech side.
I did get off and the door stay kit is in, tomorrow I will put back the trim and start on the other door.
NIKAS
Aug 20, 2019 07:53 PM
pwdrhound
Sep 13, 2016 10:44 AM
stratocaster69
Sep 19, 2015 09:57 AM
AlecS
Sep 12, 2015 10:51 AM
