991TTS Flash Not Possible?
Old Nov 9, 2013 | 12:20 AM
mikeFTW's Avatar
mikeFTW is infamous around these parts
GIAC has a flash for the 991, and 991 S, which they have already cracked
Champion motorsport sells their flash , a package flash+exhaust for the 991 S.
https://www.6speedonline.com/forums/...-tubi-bmc.html
I would expect they would do something similar. Hopefully Champion can confirm this.
Old Nov 11, 2013 | 08:05 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Aston Martin said the same thing about their ECU, claiming it was "locked". Poppy****! the flash tables are all 32 bit Hi-Lo unencryptic floating point HEX. Now accessing the flash via the OBD port is a challenge. You need some inside knowledge to get the encryption seed generator. the ECU needs to receive the correct key sequence before the ECU will allow you to read or write the flash. luckily the algorythm is pure EEC6 Ford, hacked already by many companies.
Old Nov 14, 2013 | 12:21 PM
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
Yes, we will have support soon for the 991 Turbo and Turbo S. All ECU's are encrypted, so this isn't anything new. As mentioned, we already have proprietary software for the 991 and 991S (others advertising software are flashing the PK file), in addition to the 958 Cayenne Turbo and Panamera Turbo. We will continue to offer great support for the Porsche model range.
Old Nov 15, 2013 | 08:18 PM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
If uncrackable..........then go SYVECS......simple!!
Oct 6, 2015 06:13 PM
