Split the *!@#*ing front splitter
Old Oct 7, 2014 | 09:44 AM
1Gunner's Avatar
1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold
Thumbs down Split the *!@#*ing front splitter
Has anyone had this happen to them?
It's only held together by a bead of adhesive...
Yes I did scuff it, but not anything that IMO should have caused this..
Warranty fix? or my dime??
Old Oct 7, 2014 | 10:13 AM
HotHonda's Avatar
HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !
Old Oct 7, 2014 | 11:49 AM
enzom's Avatar
enzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond repute
Can you actually see the damage from the front of the car? Your camera is underneath the spoiler. Does it retract/extend normally even with the damage?
Old Oct 7, 2014 | 12:18 PM
1Gunner's Avatar
Yes it extends and retracts normally and you can't see it from the front but I know it's there.
I've contacted my dealer who wants to take a closer look to help determine if the adhesive may have been defective (as I have suggested).
Old Oct 7, 2014 | 12:27 PM
BigRich's Avatar
BigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud of
First thought is it's going to be your dime. Unless it can be placed solely on the adhesive for fault. A dealer is going to see whatever damage you caused and say it caused the issue IMO. If you have a very good relationship with your dealer maybe they will do it under warranty "work" for you. Best of luck and let us know what happens. Interested to see if the adhesive was at fault/defective.
Old Oct 7, 2014 | 02:50 PM
991TurboS's Avatar
991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light
The only way your dealer will be able to do it for you if they cannot justify it to PCNA is to eat the cost. Porsche dealers get reimbursed for parts/labor by PCNA for true warranty issues, and they have to be able to prove it is a warranty item to get reimbursed.
Hopefully it was adhesive failure, but if there is evidence of external damage to the spoiler lip, then I would not get my hopes up.
I just went through a relatively similar matter when the ACC/PAS system stopped working, showing an "ACC/PAS not available" message on the dash. Upon inspection, the round, black, plastic housing that covers the half circle radar unit was missing, and the U shaped frame was just hanging on. It was clear evidence of some type of impact, and as a result I could not get warranty coverage on the thing. My dealer even tried to get warranty coverage for me, but PCNA rejected it.
I had to pay for a new housing, and I had to pay to have the unit realigned ($450). I didn't like it, but I really could not ague with them that there had been some external cause of the issue. I was just lucky that there was no damage anywhere else.
Old Oct 7, 2014 | 03:13 PM
1Gunner's Avatar
I just want my dealer to have a look-see and determine what's in everyone's best interest moving forward. I've always been a low maintenance customer so we'll see what happens.
If they refuse to cover it I'll DIY with glue and clamps. No biggy!!
Old Oct 7, 2014 | 03:20 PM
kip's Avatar
kip
kip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to behold
Wow, surprised it is that weak. If there are clear scrape marks at that position, it will be hard to justify warranty, but if there are no scrape marks, or there are similar weak scrape marks all over the spoiler, I would say the part is too weak for its original intended use. It is quite obvious there will be scrapes and the spoiler should withstand some scraping. I am also surprised that they didn't cover the acc cover mentioned in another post. If there was no visible damage, it is quite clear IMO that it was poorly assembled and should have been covered by warranty.
Old Oct 7, 2014 | 07:19 PM
991TurboS's Avatar
Perhaps I was not clear enough in my first post, but the radar unit was out of alignment, and could not be made operational again without an alignment process, meaning it was not just a code that could be cleared out by a technician. Probably related to the safety aspect of it and related liability issues if it malfunctioned, seeing how when operational it controls the throttle and braking system of the car.
The process involved a 4 wheel alignment on a jig of some sort, then placement of targets in front of the car, followed by adjustment of the radar unit to a certain area of contact x feet in front and x feet up/down/left/right of the unit.
This was not just replacing a missing plastic housing. The impact had knocked the actual radar unit out of alignment.
I never use the cruise control anyways, but who wants a continuous error message on their dash?
Old Oct 9, 2014 | 02:31 PM
1Gunner's Avatar
Sent my dealer the pictures above and now it's on their hoist as they attempt to re-glue where the factory adhesive let go.
No questions, no delay, no push back.
Enemy
Nov 10, 2015 08:01 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
