Racing fuel
Old Mar 24, 2015 | 12:06 AM
cephas's Avatar
cephas is infamous around these parts
Racing fuel
Hi All,
I dont have experience but will that be okay to put in racing fuel into the car just for the track day? Can the engine adjust and back to normal after a day?
And (leaded and unleaded), does it matter?
Old Mar 24, 2015 | 06:04 AM
PMNewton's Avatar
PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !PMNewton Is a GOD !
Wow, um I'm not sure where to start with this. If you would like to immediately replace your catalytic converters, O2 sensors and most of the fuel system then by all means, use leaded race fuel. Otherwise, using (unleaded) race fuel on a stock tune will be of minimal benefit. If you have a GIAC tune with the race gas option then using race fuel will actually make a tangible difference. Hope that helps.
- Patrick
Old Mar 24, 2015 | 10:53 AM
MarkCurrie's Avatar
MarkCurrie is infamous around these parts
Sunoco offers 2 unleaded versions. 100 and 104 octane - 260 GT and 260 GT plus. I use them often as in a mix with pump Gas as the highest octane I can get at the pump in Idaho is 91.
It makes a difference... Significant in fact.
Old Mar 25, 2015 | 07:03 AM
enzom's Avatar
enzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond repute
I fill up with 100 from time to time. I can't really say I noticed a difference. Maybe on a hot day at the dragstrip I would see better performance, but I am not sure it makes much of a noticeable difference without a tune. I run 93 always. I guess if you are stuck in a state where only 91 is available, you would feel a difference running 100.
Old Mar 30, 2015 | 07:13 AM
rjn21's Avatar
rjn21 is infamous around these partsrjn21 is infamous around these parts
The 991 Turbo S stock mapping is set to only advance ignition timing to its max at the detonation point of 98 RON = 87 MON = 93 AKI (roughly). Any RON rating above 98 (93 AKI), in a stock car, will make no difference as maximum advance occurs at 98 RON. This assumes the fuels are otherwise equal, which in EU USA etc they are (or should be), because fuel is so tightly regulated in its refining process and retail additives. If a tuning map has been applied that successfully can further advance ignition timing to a point just prior to the detonation point of a higher RON rating, that may give some additional power, but it wont be massive.
Old Jun 14, 2015 | 06:43 PM
wrs's Avatar
wrs
wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !
Well when I added the Sunoco 104 to my car on Friday night, I added as much as 3mph on trap speed and .2s ET compared to 93. I only added 3 gallons to a 1/4 tank and the FVD module picked it up resulting in much better performance. See my post on SS100 where I posted the slips.
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Sales@RSW
Sep 3, 2015 09:34 AM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
