ESMOTOR tuned 991 TTS - 9.62 @ 143 mph (230km/h)
I saw somewhere on the ekanoo instagram page indicating the car did 2.2 s 0 - 100 kmh and 5.2 secs 100-200 kmh...
which does not add up...
A car doing 100-200 kmh in 5.2 secs is somewhere around a 5.9-6 second 60-130 mph car which would then be a car to trap in the mid 135-137 mph range one would guess.
Just to compare with my car FBO stock turbo 3,8 DI with a 1/4 mile 135.6 trap I think my vBox on that run showed 0-60 in 2.5 (street tires) and 60-130 was 6.7 which is around 100-200 5.8 sec. So the better tires and trap prep with upgraded turbos for more top end makes this possible. I have heard the 991 stock fuel system has more capacity than the 997.2 so I think that's why you are seeing 991's doing 140+ traps.
I'm betting we will see a GIAC / Champion upgraded turbo 991 do this shortly.
Good job ES Motors.
"The 2014 Porsche Panamera Turbo S houses 2 new turbochargers, larger compressors, uprated injectors, pistons made from a new aluminium alloy and specially coated piston rings"
sdg1871
Sep 12, 2015 06:54 AM
