991 turbo vs 991 turbo engine difference
Old Sep 30, 2015 | 10:48 AM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
991 turbo S vs 991 turbo engine difference
Hi Guys,
its been a long time
Guys, can't find anything about differences in engine potential between those two.
thanks for input
Karol
Old Sep 30, 2015 | 11:03 AM
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
I'm not sure if there are any slight hardware differences but multiple tuners have stated the outputs are the same once tuned.
Old Sep 30, 2015 | 11:39 AM
GT3Fan24's Avatar
GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !
Difference between what ones? Your title says 991 Turbo vs 991 Turbo
Old Sep 30, 2015 | 11:47 AM
ecpChris's Avatar
I took it for granted he meant turbo vs turbo S. Usually that's how these threads go
Old Sep 30, 2015 | 12:01 PM
GT3Fan24's Avatar
Figured. Just being a weenie.
Unless you want PCCB, then the TT is great because with minimal mods and money you can get plenty of HP. Exact spec TT vs exact spec TTS you will spend a lot more for that extra HP when you can get it for cheaper with a few mods. I guess the can of worms will be, yeah but that could void the warranty.
Old Sep 30, 2015 | 03:14 PM
Techart claims its 580 vs 620 with their box.
Old Sep 30, 2015 | 03:17 PM
Turbochargers, coolers are same? How about capacity of injectos system? How much it can take?
Old Oct 1, 2015 | 05:48 AM
justthebest's Avatar
justthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud of
Speaking from the logic perspective, I believe they'd be the same - it's clear that a change in software can achieve the higher power, so why would a for-profit corporation change anything that they wouldn't have to?
I'd put my money on TT vs. S being same everything, save for software.
Old Oct 1, 2015 | 06:59 AM
GT3Fan24's Avatar
I beleive you are correct, hence my comment the real difference is the PCCB. Ovbiously the TTS comes standard with a few things that are options on the TT.
Old Oct 1, 2015 | 07:03 AM
shifter_'s Avatar
shifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond repute
The S is basically just a fully performance optioned Turbo with the better tune thrown in.
But not exactly.
S's have continually dyno'd higher with the exact same aftermarket tune.
Some say the turbos are slightly larger.
It has been reported that the replacement part number on the engine is different so there is some difference.
Old Oct 1, 2015 | 02:03 PM
porsche42's Avatar
porsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to beholdporsche42 is a splendid one to behold
I read in Christophorus article on the Turbo/Turbo S the only difference is the ECU programming. Of course that does not explain how a tune for the S and non S should make the same HP/TQ.
Old Oct 1, 2015 | 05:54 PM
But not exactly.
If you (OP) want the true answer, I'd bet calling the local parts department and comparing these numbers for yourself would yield the info.
Old Oct 2, 2015 | 07:08 AM
Where are all the tuners???
Old Oct 2, 2015 | 07:11 AM
wrs's Avatar
wrs
wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !
They don't. Look at WhiteTTS dyno vs some of the TTS ones like for example mine with Cobb or FVD or SDG1871 from Champion with GIAC.
Old Oct 3, 2015 | 09:07 PM
webcarconnection's Avatar
webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !
My TT w COBB and Exhaust put the same whp and TQ that my friends TTS with COBB and Exhaust, same dyno, same tuner
