Installed Cobb Stage II and BY-Design Intercoolers
Old Oct 2, 2015 | 09:02 AM
  #46
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
Originally Posted by wrs
I hope to be going but something just popped up with my grandson whom we have custody of.
Here is what I was basing my comments on:
Yeah I figured but had remembered reading he mentioned something of switching exhausts so I went back and checked.
Good luck with the grandson situation. Family first
Old Oct 2, 2015 | 09:39 AM
  #47
longboarder's Avatar
Originally Posted by webcarconnection
Nice vids like always long... What was your trap in the 1/2 mile that day? That last 991TT at the end was fast, do you know the exact mods?
I didn't get a trap speed until after 1pm. By that time it was 95 degrees with a 20mph headwind. Best was 167.X.
Originally Posted by ecpChris
Damned if you do, damned if you don't
I'm sure you guys are probably already doing this, but try throwing the OEM DVs in. Should be able to troubleshoot easier with the logs at your fingertips. I hope you get it sorted.
Agreed on the DVs. My DVs are the same ones that came with the car new. So are my plugs. Car has 36,000 miles and I'm running 30psi midrange. If the original DVs and plugs are still good in my car, they are likely fine in everyone else's.
Old Oct 2, 2015 | 10:24 AM
  #48
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Originally Posted by Tom@Champion
Not to mention the less-then-optimal conditions under which the dyno testing was performed (i.e. lack of rpm signal or data-log during the GIAC run) which technically would make it impossible to plot a TQ curve, yet you have a pretty clearly plotted TQ shown. The whole thing is a bit confusing, to be honest.
This is incorrect. All that is needed to plot torque is speed ratio, horsepower, and vehicle speed. All of which I explained above. That speed ratio is a constant. Only changed by wheel radius, tire sidewall height, gearing, or slipping clutches. None of which occurred or were changed in the session. This speed ratio was easily acquired using the data from the Cobb datalog. I hope it is not presumed that different tunes result in a different speed ratio.
How is a customer with a competitors product expected to log their car if that product does not supply them with a means to do so?
The speed ratio data gathered from the Accessport's datalogs is equal under any tune or any condition in 4th gear as long as the four things listed above are not changed. Aside from that the speed ratio used for the torque calculations were the same for Cobb and the Competitors dyno runs so the percentage change in gains would remain identical regardless.
If everyone forgot about the torque and looked at the plots with just horsepower you can still clearly see the difference in linearity, consistency, and gains between the two, especially in the mid range.
The premise of this post by Nigel, I believe, was to compare two tunes under the same conditions. He chose to do this at a 3rd party facility as to not affiliate any interested party and come to his own conclusions on which tune fit him best. We encourage all to do the same!
DSports dynojet 424linx is what they use to do before and after tests for all of their unbiased magazine publications so consistency on this dyno is vital for them. I honestly don't know of a better dyno he could have picked to perform this test in this manner.
Thanks everyone!
-Jon
Old Oct 2, 2015 | 10:58 AM
  #49
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Great, I learned something new today.
Just because GIAC does not supply the means to data log, that doesn't mean it can't be done. You're implying that GIAC software is somehow "hidden" or unreadable...when the reality is all you need is a Durametric, PIWIS, or GIAC logger to conduct the same type of logging that the AP offers. The GIAC logger even samples at a significantly higher rate.
While I agree that was the premise, I still hold firm to my previous statement that the results are skewed by the fact that there is an (admitted) hardware issue with the car. Is it not safe to say that your software may react (or not react) completely differently to this hardware issue then other software might?
Old Oct 2, 2015 | 03:39 PM
  #50
Apologies if it came across that way but in no way did I insinuate that the ability was hidden or unreadable, all I stated is that the customer was not given the means to do it. Simply implying the ability to datalog was not included or easily accessible on that particular product.
Verbatim: "How is a customer with a competitors product expected to log their car if that product does not supply them with a means to do so?"
These other logging options are not easily accessible. If they are located they are an additional expense on top of the already purchased calibration. PIWIS may work ok on the dyno, but is extremely hard and extremely expensive for the average consumer to get. Not to mention very cumbersome to use while on track. The Durametric is a great tool for other features but I wouldn't advise using the data from it to form a refined calibration. I have yet to see our competitions logging capabilities in the hands of a consumer, not to say it isn't, but there is little ever spoken about their logging ability by their customers.
Logging in my opinion is just as crucial as tuning. It not only provides data needed for engine calibration, but it is a wonderful tool in diagnosing mechanical issues if you know what to look for. As is the built in trouble code reader on the Accessport.
The Cobb Accessport includes the ability to datalog with a blistering fast log rate. The log I posted before had 44 parameters selected and sampled at 49hz. That means it records 44 unique channels of data from different outputs and sensors 49 times per second. That is 2,156 unique data points gathered per second.
Any individual who modifies their car should have the ability to easily and honestly monitor their car's health and status.
-Jon Hebbeln
-Porsche R&D Calibrator
Old Oct 2, 2015 | 04:01 PM
  #51
webcarconnection's Avatar
webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !
Originally Posted by sdg1871
By now I have seen thread after thread claiming that GIAC basically makes crap power and 100 lbs ft less torque than Cobb. We will see who makes more power at comparative events.
1. Our October 7th Atco rental day; and
2. Slipstream's Oct 17th roll races at Pocono.
3. The upcoming ShiftSector event in California.
I am in numbers 1 and 2with RedGutz. Hope to see as many Cobb tuned cars as possible.
If the Cobb torque claims are to be believed a stage 2 Cobb tuned car with stock ICs should be as fast or faster than my GIAC Stage 2 plus tune car with Champion ICs. Let's see if some of these amazing Dyno runs are proven in the real world.
Time to GoPro up and record for the Porsche world to see.
Amen lol
If someone have vbox let us know the 60-130 times, Wonder where am I in comparition of GIAC stg two
Old Oct 2, 2015 | 05:07 PM
  #52
Originally Posted by Markblackwell
Webcar,
I raced OP and got him by a car length at this same event, I raced this black PP Perfornance 991 and he got me by a little over a car length I believe he was running meth but can't confirm. I also raced longboarder and he got me by about 3 cars, I also had a passenger on all my runs ( black 991 had passenger as well )I'm hopping to close that gap by a lot at shift sector, with my new tune and IC'
Great, what was your and black PP Car MPH in the 1/2 mile?
Old Oct 2, 2015 | 05:08 PM
  #53
167 is good
Old Oct 2, 2015 | 06:49 PM
  #54
-Jon Hebbeln
Like Sambo will say ... "and now I just drop the mic" lol
Just kidding
Old Oct 3, 2015 | 01:19 AM
  #55
Markblackwell's Avatar
Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !
Traps speeds timers worked intermittent, I got a couple 162 and a 166,
Old Oct 3, 2015 | 04:44 PM
  #56
Oh so 166 for you with what mods? Your only 1 mile short of Long .2 "Beast" hehehe
Old Oct 5, 2015 | 07:45 AM
  #57
-Jon Hebbeln
Understood. I'm not taking anything away from the convenience or value the AP offers. Just clarifying.
But back on topic for a sec. Do you think it's possible that the GIAC and Cobb software could react differently to the "hardware problem" that the OP mentioned?
Old Mar 1, 2016 | 08:34 PM
  #58
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
OP, all of these dyno values are worthless. None are even remotely within reason.
By the way didn't we race at NoFlyZone?
Well it's a TT not a TTS, I assume that is the case from the OP's handle and at first I thought the hp numbers were low in the first plot but I just figured that is because it's a TT. IMO this shows the TT can be tuned up to a stock TTS but it won't tune to the levels a TTS will.
It also has a stock exhaust.
Originally Posted by shifter_
There's entirely too much secrecy, non disclosure and things that don't add up in this thread.
I'm checking out.
There are also many GIAC dealers that can offer custom tunes. We just custom tuned SDG's car, and we have custom tuned dozens of 997.2 Turbos....you know the 997.2 Turbos that NO ONE has beaten yet.
I know of no stock Turbo 991 or 997 that has ever beaten Longboarder's GIAC tuned 997 at an event for example.
If you win I will be the first to bow down, congratulate you and shake your hand
Hey Tom,
Remember.... Wow how time flies!
Started from the bottom.....
Remember....
Remember.....
Old Mar 1, 2016 | 08:42 PM
  #59
Boom!!!
Old Mar 5, 2016 | 01:01 PM
  #60
E-Gear's Avatar
E-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond repute
Wow, I just read this entire thread post by post and it is very obvious to me who are the vendor cronies, wannabees and who are the real racers.
When it comes to racing, there is never 100% full disclosure transparency, but man, some folks in here sure like to bash one party over the head to simply push the best interest for their preferred vendor.
I applaud you Mr. White991TT for simply sticking to it and letting your driving, car and times do the talking. Remember, there will always be doubters out there. Typically because it is not them doing it.
Times like these is the reason why I race for money - I like shutting ****'s down and taking their money. Granted, my DD 997.2 TTS was decently quick (10.26's); will soon start to work on my 2016 TTS. In the meantime, my 9.08@153 C6Z06 will fill the gap. I can drive that car to and from the track and I love it when cocky P-car owners challenge me (track or street)...the looks on their faces after the beat down is priceless; even more so after I share pics of cars or key/fobs of my 997.2/991 both TTS letting them know I am not one brand man. I like ALL brands!!!
Point is, everyone can go fast with careful planning and execution - NOT ONE tuner has all the answers or the only answer...please give folks their props and move on vs. bashing any time of accomplishments...street/track/or dyno. All of these vendor vs. vendor crap is silly - and it comes mainly from the cronies non driving *****.
There, I spoke my peace. Flame suit is on.
Thanks,
E-Gear
