Michelin PSS
Old Oct 25, 2016 | 07:05 AM
  #46
1Gunner's Avatar
1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold1Gunner is a splendid one to behold
Originally Posted by reisskhan
Here in the U.K N rated tyres are a must for warranty etc
Not the same over there in U.S?
Bummer.
Can't speak for US owners, but in here in Canada that's not the case.
With performance tires being short-supplied, do UK dealers expect you to park your car and collect dust in the event you are unable to source proper N rated in TT/S sizing?
Old Oct 25, 2016 | 09:11 AM
  #47
shifter_'s Avatar
shifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond repute
Warranty on what? The whole car? They can't tell you what tires you have to run in order to still cover the engine etc under warranty. Yes if they could prove that some issue you had was a direct result of the tires they could deny that claim. But this holds true for any mod. If you get an aftermarket exhaust that doesn't void your entire warranty on the engine and drive train etc.
Old Oct 25, 2016 | 09:15 AM
  #48
justthebest's Avatar
justthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud of
In the US, this is generally correct. It has to do with a law (Magnuson-Moss Warranty Act) that sought to protect consumers. However, other countries are free to legislate / litigate as they see fit, so your rationale is not necessarily correct in the UK.
Old Oct 26, 2016 | 03:08 AM
  #49
reisskhan's Avatar
reisskhan is infamous around these parts
Yes must be definitely different over there as here to apply for an extended warranty (Porsche changed the rules so cars upto 15 years old and 100,000 miles max can apply for it) need to go through a 111 point health check
They check stuff like:
Rev ranges
Must have an original Porsche battery
N Rated tyres
Standard exhaust
Standard suspension
Full service history
If it fails the 111 point check you need to rectify the work first
So not as straight forward here i guess
Old Oct 26, 2016 | 06:38 AM
  #50
1Gunner's Avatar
I could be wrong but I would contend:
Because a Porsche dealer must have their used car wearing N Rated tires (or Tyres ) in order to qualify for Porsche's extended warranty program, does not mean that car must remain wearing N Rated moving forward once they have worn out, to maintain full coverage as outlined within the extended warranty program.
I've changed exhausts, tires, rotors, brake pads and even wheels to off brands and still maintained both the original warranty and in other instances the extended warranty with my Porsche dealer.
gtron
Mar 3, 2020 02:00 PM
N2SPEED
Jun 13, 2016 08:50 PM
Car-Narcissist
Apr 9, 2016 07:31 AM
