Launch control at 2k rpm?
Hello, everyone.
After my last upgrade the car will not launch correctly with Launch Control due to the increase in power.
This weekend I went to PBIR.
I left my street tyres at "full load" setting.
On 2 runs on sport +, I held the gas while holding the brake.
While the engine was at about 2k rpm (maybe lower), I release the brake and floored the gas.
Both times the "Launch control activated" lit up after releasing the brake and flooring it.
It did launch flawlessly than the usual way (it would cut power, buck, etc after the mods)
How much lattitude is there with it?
Suggestions on best launching strategy for it?
You may already know this but you need more tire..R888's were my choice and although they cannot hold the power on the street of a launch they do on a well prepped track..I went through many days of testing with Sam's help trying to figure out what the problems were after my upgrades..erratic shifting...cutting power etc until I got the car to the track and with R888 it launches perfectly..the added power at launches manifests weird conditions on the street..I posted videos of this...an example here and note this was a non-lift run...gas was held to the floor...the car reacted as shown...not me
That's the usual way. That is not what I'm talking about.
https://youtu.be/ebsNpO8Fxk4
This part of my post is the one that has me puzzled:
"While the engine was at about 2k rpm (maybe lower), I released the brake and floored the gas.
Both times the "Launch control activated" lit up after releasing the brake and flooring it".
I wonder how high can the rpms be held using this method without damaging anything.
Originally Posted by longboarder
Wait did you turn off PSM? Some of the characteristics you describe on LC occurs when you don't turn PSM off.
Guys PSM completely screws up the launch on our cars. It must be deactivated if you want the launch to be optimal. I have even tested it in the rain and once in rain/mud. It always works better from PSM is off...and I'm not meaning a little bit better...it's a lot better.
What I have found at least with my car is that if there is not sufficient traction for the tires to hook the car does better ETs with PSM on.
If the car does have sufficient traction for the tires to hook the car's ET arr better with PSM off.
But I'm talking a full power launch on launch control without any sort of throttle modulation
I can only speak to the 991 platform I've been countless launches at the dragstrip with PSM on and off with launch control
I see. You are referencing no throttle modulation but I modulate the throttle in most circumstances with both the 997.2 and 991 (especially the 991 at Stg 4 power with stock PZeros).
So not sure if this helps the OP with his launch issue but it sounds like he's got PSM on and that could be the issue.
The times I tried with PSM off using launch control were not pretty with my car, before upgraded turbos + meth. I do not know if now it could.
Well since my memory is still long enough to deal with this and I encountered all these issues just two months ago here is what I found. With the new PZero N1s don't use TC/PSM on the street and you can get 1.5x 60ft. If you don't use TC at the track, you will get 2s or worse 60ft on street tires. I didn't get anything under 2s until I ran with TC on at the track with the new N1s on a prepped track. My car was better from a dig on the street than at the track, always. So maybe that's just my car but that was my experience. The power at Stage 4 is more than the software in the car was designed to handle. It's pretty clear that Adam can shift manually by sound from watching his most recent video. I could never do that, the engine was just too fast for me in first gear and I almost always hit the rev limiter. The nice thing about the Fcar is that I have the LEDs on the steering wheel to help me shift manually now.
