Rear seat removal guide on Porsche 911/991S
Old Jun 13, 2012 | 09:28 AM
iambon's Avatar
iambon has much to be proud ofiambon has much to be proud ofiambon has much to be proud ofiambon has much to be proud ofiambon has much to be proud ofiambon has much to be proud ofiambon has much to be proud ofiambon has much to be proud ofiambon has much to be proud of
Hi everyone,
I have got many requests about how to remove the rear seat cushion as well as many people want to see the 991 rear without rear cushion.
Today, I decided to remove my rear seat belts because I want to save some weight (may be better to diet, i am 80 kg by the way).
The process is quite simple and straight forward, i do the photoshop to show your guys, enjoy.
Old Jun 13, 2012 | 09:38 AM
iambon's Avatar
The rear does look pretty bad though. :P
However, the good thing is, with the removed rear seat cushion and i can sit quite comfortable in rear (i am 182 cm).
Old Jun 13, 2012 | 09:40 AM
iambon's Avatar
Here is my seat without rear seat belts.. save some weight
Old Jun 13, 2012 | 09:44 AM
iambon's Avatar
I also fixed my rattled left rear quarter window, just use 3M to fix it now no more rattles on bumps. I think it is a bad design to have only 2 screws and 1 plastic clip to hold the entire rear quarter window. Mine is easily rattling when I try to push the rear quarter window in the lowered-middle section.
I do not like the way Porsche attach its rear quarter windows on their sport car, since i also had my rear quarter window rattling on my previous Cayman S 2011. Why not just glue it like others?
Old Jun 13, 2012 | 09:56 AM
G997's Avatar
G997 is infamous around these parts
What kind of 3M tape?
Old Jun 13, 2012 | 10:12 AM
iambon's Avatar
It is a normal "3M acrylic auto double sides foam tape"
"3M Acrylic Auto Double Sided Foam Tape 10mm 3m is characterized by high performance peel and shear adhesion, high internal strength, good conformability and excellent plasticine resistance. The acrylic foam core has unique viscoelastic properties that allow it to elongate and relax when put under load, thereby minimizing stress on the adhesive bond line. These properties allow the tape to bond more effectively to a wide variety of automotive surfaces.
Typical applications for the 3M™ Acrylic Auto Double Sided Foam Tape 6mm 3m would include body side moldings, stainless steel, ABS and PVC rocker panels, hood scoops, wheel flares, door edge moldings, nameplates, ornamentation, luggage rack slats, wind and rain deflectors, dashboard overlays, sunroof wind deflectors, bug deflectors, tail light covers, tailgate weather seals, cladding and rocker panels, running boards, and running lights"
Old Jun 13, 2012 | 10:53 AM
bbywu's Avatar
+ rep!
Excellent post!
Old Jun 13, 2012 | 02:34 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
Originally Posted by iambon
I also fixed my rattled left rear quarter window, just use 3M to fix it now no more rattles on bumps. I think it is not a bad to have only 2 screws and 1 plastic clip to hold the entire rear quarter window. Mine is easily rattling when I try to push the rear quarter window in the lowered-middle section.
Great job!
From looking at the pictures, it strikes me that it wouldn't be hard for the track guys to fashion an opening bracket for that window to get rid of their buffeting.
ChuckJ
Old Jun 13, 2012 | 02:39 PM
fbroen's Avatar
fbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to behold
Thumbs up
Thank you for this. Very much appreciated.
Old Jun 13, 2012 | 06:21 PM
Palden's Avatar
Palden is infamous around these parts
Great post. I wanted to remove the rear cushions to better fit car seats in back.
Old Jun 15, 2012 | 10:06 PM
Zmoney's Avatar
Zmoney is infamous around these parts
How much weight is lost with removal of seat pads?
My seatbelts are awesome as they match my exterior paint and look great on black leather
Old Jun 15, 2012 | 11:29 PM
exponential's Avatar
exponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to behold
Would be great to know how much weight saving when rear seat belt removed. Thanks
Old Jun 16, 2012 | 08:22 AM
iambon's Avatar
The weight of a rear seat belt is
0.69 Kg
1.52 Pounds
24.34 Ounces
So removed 2 units would be
1.38 Kg
3.04 Pounds
48.67 Ounces
= better to skip one full meal.
Old Jun 21, 2012 | 12:42 AM
Thanks for the information. Every pound count !!!!
Old Jun 24, 2012 | 07:16 AM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
great thread - looks like it would be a breeze to replace the stock rear centre tunnel with the upgraded stitched version - now to get my dealor to order a car with the extra leather option so i can swap out!
