Engine stumble/hesitation around 2500 RPM?
Old Feb 18, 2013 | 12:09 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
Originally Posted by 991s
Took my car back to the dealer this morning and the tech came for a drive with me and he could also feel & hear the "stumble/hesitation". He plugged my car into his diagnostics and, of course, no faults or CEL's so I was told to drive it and see if it gets better or worse or goes away!
Techs nowadays don't seem to be able to "think" to try to figure out problems. They just rely 100% on their PC's and diagnostics and if there aren't any fault codes then everything must be fine. In reality it's not.
This was a wasted trip and the outcome was as I expected. However, my engine hestitation remains. Frustrated.
That's why I like Boardwalk in Dallas; they don't quit until it's fixed. You needed a trip to Dallas didn't you? In the meantime, you might give Cliff Blackshear (head tech) a call there to see if he's ever heard of the problem.
ChuckJ
Old Feb 18, 2013 | 12:31 PM
runner1021's Avatar
runner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to behold
Here's another possible cause for the stumble/hesitation (post#9) that illustrates the difficulties with no codes/cel:
https://www.6speedonline.com/forums/...ml#post2540694
Old Feb 18, 2013 | 01:37 PM
991s's Avatar
991s is infamous around these parts
ChuckJ
Thanks, I'll give him a call. All my local dealers are the same, whether it be MB or Porsche or BMW - if it doesn't throw a code they can't or won't do anything.
Old Feb 18, 2013 | 01:52 PM
991s's Avatar
Thanks, I appreciate the link and it sounds similar to my problem. I thought it could be the MAF sensor but the tech doesn't share my opinion!!
Old Feb 20, 2013 | 02:17 PM
G997's Avatar
G997 is infamous around these parts
Its got to be related to the previous work that was done....
Old Feb 20, 2013 | 02:25 PM
991s's Avatar
I don't know if it is or isn't but I suspect the same thing. I wish I knew for sure.
I didn't feel the stumble before the last repair because I was/am breaking the car in and was driving only in auto mode. In auto the car changes gear before the revs reach 2500 rpm under light throttle. Once I got the car back and got a few more miles on it I starting drivng in manual mode and that's when I started to feel the stumble.
Old Mar 4, 2013 | 07:21 PM
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
I too have the stumble between 2500 and 3000 RPM on my recently delivered C2S. I remembered seeing this post and ignoring it when I saw it, but now it's happening to my car too, so I was checking to see if anyone had a solution yet.
Old Mar 5, 2013 | 01:57 AM
00C2Cab's Avatar
00C2Cab is a jewel in the rough00C2Cab is a jewel in the rough00C2Cab is a jewel in the rough
I too have a stumble at 2500 RPM when drive the PDK in manual mode and not pressing the throttle hard. It is intermittent. Will call the local dealer for an appt.
Old Mar 5, 2013 | 08:42 PM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
Checked today. No stumble on the base anywhere between 2500 and 3000
Old Apr 13, 2013 | 07:43 AM
mtony's Avatar
So I mentioned the hesitation my C2S has between 2600 and 3000 RPM at moderate load on a Porsche survey I received, and the next day got a call from my dealer. I explained what I was noticing and although he was quite surprised I could feel it, he said that it was a "feature" of the PDK, but encouraged me to bring it in once my break-in was over. I have a feeling this is going nowhere, but I'll bring it in to give them a chance to see if they feel it too.
Has anyone else had this addressed by their dealer?
Old Apr 13, 2013 | 04:58 PM
TTCarrera's Avatar
TTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of light
Still breaking my engine in and taking it easy, however, I notice that when I'm in manual mode (PDK) and accelerating in 2nd (gently) the engine hesitates/stumbles around 2500 rpm but it's fine once past 3000 rpm. I don't notice it in any other gear. Is this normal? Is it the throttle bodies opening? Or is it a fueling/ECU issue?
Anyone else seen this issue?
I had this when the car was brand new, under 100 miles. Though it was the Vario-cam, like others suggested
Frankly, I'd forgotten about it. Now at 700 miles, I haven't noticed it. Seems to have gone away.
As for the techs not seeming to care about solving the problem: they have no choice. The engineers at Porsche and their diagnostic systems are pretty sophisticated. A local tech, no matter how well trained, who decides to go rogue and become an artist instead of a scientist, is crossing the line. He has no incentive to do that. Doing something out of the box at this early point could actually damage your engine.
Old Apr 14, 2013 | 05:28 PM
LotF's Avatar
LotF has a spectacular aura aboutLotF has a spectacular aura aboutLotF has a spectacular aura about
The car most likely has a noisy sensor. Since it's related to RPM, the most likely culprit is any sensor which measures the camshaft position. The tech should have a history of the most replaced sensor on the car. If the most replaced sensor is related to the camshaft, start there.
Old May 2, 2013 | 08:45 PM
Cutters68's Avatar
Cutters68 is infamous around these parts
I'm experiencing it when I accelerate in 4th 5th or 6th gear between 2500-3500 rpm. Still have 400 miles to go on break in. Really haven't noticed it in 2nd or 3rd. Thought I would give this thread a bump to see if anyone had gotten an answer. More annoying than anything else, that is unless it gets progressively worse.
Old May 3, 2013 | 05:08 AM
mtony's Avatar
Still haven't taken it in. Waiting for the break-in to be over. Definitely hasn't gotten worse, but no better either.
Old May 3, 2013 | 05:38 AM
ChuckJ's Avatar
Is this when it is warm or cold? And is it a smooth reduction of power surge or misfire?
ChuckJ
