Engine stumble/hesitation around 2500 RPM?
Old Aug 8, 2014 | 09:14 AM
  #166
beemer guy's Avatar
beemer guy is a jewel in the roughbeemer guy is a jewel in the roughbeemer guy is a jewel in the rough
The wonderful thing about forums like this is that even though this problem might only affect a small percentage of cars, people from different parts of the country can be aware of similar issues. It may be helpful - I'm just guessing here - if one person spearheads the effort to get PCNA to acknowledge and fix the issue, and writes a letter that says something like:
"I am experiencing this issue and my dealer says that it's normal. However, there are fifty-seven other people that I am personally aware of that have the same issue and have complained about it and attempted to have their local Porsche dealer address it, all to no avail. These are the VINs for those cars...".
PCNA can then (if they want to) pull up all of the warranty claims on all of those cars and see if there is a common link.
If that doesn't work, at the very least it may help should anyone in that group decide that they want to file a complaint with the NHTSA or God forbid, file a class action.
I'm just throwing ideas out there.
Old Aug 8, 2014 | 01:28 PM
  #167
pcs99's Avatar
pcs99 is infamous around these parts
Unfortunately I am also one of those that has this problem. Same response from the dealer.....'operation is normal'. My previous Boxster S had the exact same issue, with the same response from the dealer. I upgrade to a C4S in the hope that power delivery would be smooth......no luck. Love the car etc etc.....but it's very annoying and once noticed it drives one mad with every outing in the car.
My solution will be to hand the car back after the lease is up and move on to something else.................
Old Aug 8, 2014 | 01:34 PM
  #168
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
I suggest you ask your dealer to re-install the operating software that they did when they received the car. I had a problem with the indexing on the window and this solved the trick. I suspect there is something wrong with the cam timing mechanism.
ChuckJ
Old Aug 9, 2014 | 02:48 AM
  #169
PorscheCrazy's Avatar
Old Aug 9, 2014 | 09:59 AM
  #170
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
@PorscheCrazy.
Sadly the majority of stumbling cars are 100% stock with no mods whatsoever.
In addition, the problem definitely developed after several 1000 miles.
Thanks all the same.
Old Aug 9, 2014 | 10:10 AM
  #171
stealthboy's Avatar
stealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud of
Originally Posted by PorscheCrazy
I have the stock exhaust and have this problem, so that is not the culprit.
Old Aug 9, 2014 | 10:20 AM
  #172
certified_prime's Avatar
certified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of light
I did not notice it so much in car when it had the factory base exhaust on it. Now that I deleted the center with a cross pipe, I did feel it under hard acceleration.
Old Aug 9, 2014 | 10:31 AM
  #173
runner1021's Avatar
runner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to behold
Directly from the Porsche website:
VarioCam Plus System
VarioCam Plus is a two-in-one engine concept for adjusting the intake camshafts and switching the lift of the intake valves.
The system first differentiates between driver inputs that typify normal, everyday driving and those inputs that demand maximum performance. The electronic engine management system then seamlessly adapts valve operation to the prevailing conditions.
This results in instant acceleration, extremely smooth running and an extraordinary level of tractive power, but with a comparatively low level of fuel consumption.
Two items stand out to me:
"Seamlessly, and extremely smooth running"
Unfortunately, my car exhibits neither.
Old Aug 9, 2014 | 10:42 AM
  #174
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
I get sick to my stomach reading the problems you guys are having. My 991 will be out of the shop soon, and I'll soon be driving it. I can't imagine something like this happening to it after going through the purchase and fixing it up. I know all of you are in the same boat. If I start experiencing this, I'm driving right down to Atlanta and staging a boycott in front of PCNA's US headquarters. Any of you are welcome to join me!
Imagine what a PR disaster that would be with a dozen 911's parked at the front doors refusing to leave. The local/nat news would pick it up in a second!
Old Aug 9, 2014 | 05:58 PM
  #175
naples991's Avatar
naples991 is infamous around these parts
Exactly I was thinking the same thing if this does not get resolved. Can you say CNN
Can get a lot of Porsches to show up if it ever came to this.
Old Aug 10, 2014 | 05:08 AM
  #176
Go123's Avatar
Go123 has a spectacular aura aboutGo123 has a spectacular aura about
Can someone post a video clip of the tach when this is occurring. Thanks
Old Aug 10, 2014 | 06:21 AM
  #177
ChuckJ's Avatar
This is why I think that there are issues in the electronic management system software. Has anyone tried taking it to the dealer and asking them to re-install the software that they put in when they received the car for delivery?
ChuckJ
Old Aug 10, 2014 | 06:32 AM
  #178
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
Can't really see the tach doing anything unusual.
Old Aug 10, 2014 | 06:39 AM
  #179
Money2536's Avatar
Money2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond reputeMoney2536 has a reputation beyond repute
The RPMs don't drop or change. This is part of the reason why techs don't believe there is a problem. You also don't get enough audible change in the exhaust not to capture it in a video. It's annoying in the seat of you pants coming from the rear of the car.
Old Aug 10, 2014 | 07:49 AM
  #180
stealthboy's Avatar
There's nothing to see on the tach. It's something you feel. Maybe if the car were put on a VERY sensitive dyno you could get something... But it seems to be subtle enough that it's only apparent to the driver.
One interesting thing I have noticed on the tach, however, is a bit of a change of RPM at idle. I don't know if it's related to the stumbling up near 2500, but my idle seems to have gotten a bit more rough in the same time frame as the hesitation has been coming on. When I sit at idle the RPMs seem to search around a bit.
