Engine stumble/hesitation around 2500 RPM?
Old Oct 22, 2015 | 09:02 AM
  #511
MMK110464's Avatar
MMK110464 is infamous around these parts
Originally Posted by georgefu
MY 2013 911/50 3.8ltr (w/o power kit)
Thanks for the quick reply. Beautiful car by the way.
Would you mind sharing the exact IPD plenum model you installed?
Did you do anything else to the car when the IPD plenum was installed (no matter how insignificant it may seem)?
Enjoy it in good health.
Old Oct 22, 2015 | 09:40 AM
  #512
georgefu's Avatar
georgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant futuregeorgefu has a brilliant future
Thank you! Not sure about the exact model number but IPD has only one plenum specific to the 991 C/S. No, nothing else was done during installation.
Old Oct 22, 2015 | 11:31 AM
  #513
stealthboy's Avatar
stealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud of
Originally Posted by bents
I have this issue on my 2012 991 C2S PDK. Car is new to me, 11K miles.
When in 1st/2nd/3rd low in the revs, it stumbles around 2250 - 2500 rpm. It's just a short stumble, like a hiccup in the power delivery, almost as if your foot just lifted slightly off the accelerator. I notice it mostly in traffic, when progressively applying the gas pedal between 10-30% of travel. Don't notice it when the gas pedal is applied more aggressively.
This is exactly right. Welcome to the club.
Old Oct 22, 2015 | 11:36 AM
  #514
stealthboy's Avatar
Did you install it yourself?
And can I assume this is the one?
http://ipdplenums.com/products/plenu...-dfi-carrera-s
Old Oct 22, 2015 | 06:29 PM
  #515
georgefu's Avatar
No, I did it at the dealership. Correct, that's the plenum..
Old Oct 22, 2015 | 08:28 PM
  #516
runner1021's Avatar
runner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to behold
Well, anyone else brave enough to give it a try?
If I could see one or two more confirmations I'd do it tomorrow.
Old Oct 22, 2015 | 11:24 PM
  #517
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
I agree! But the website suggests a professional install. I wonder why? As I recall plenum installs in a Cayman, for instance, was a pretty straightforward bolt in. Is the 991 access the issue?
Old Oct 23, 2015 | 05:30 AM
  #518
beemer guy's Avatar
beemer guy is a jewel in the roughbeemer guy is a jewel in the roughbeemer guy is a jewel in the rough
I have several thoughts. OT, I apologize.
  • Has anyone ever done a before and after dyno on this item to prove the 15 horsepower increase?
  • If it were really that easy (a modified plenum) to get another 15 horses, wouldn't Porsche have already done it?
  • Is it just me, or does it look like the exact same part for the 3.4 and 3.8, with the same pictures, yet the 3.8 version is $50 more?
  • It does look like a very nice part, and I don't mean to impune the manufacturer. It just brought up some questions in my little mind.
Old Oct 23, 2015 | 06:27 AM
  #519
stealthboy's Avatar
I would try this in a second if indeed it will help our stumbling issue. If a dealer installs it will it keep the factory warranty in place?
Old Oct 23, 2015 | 07:39 AM
  #520
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Most folks with the stumble are not looking for additional HP, but rather a smooth delivery of power under normal driving conditions.
There are Motorsport companies out there who perform ECU tunes and install similar components all day long, and are "unofficially sanctioned" by Porsche dealers. (I can think of two that are sponsors on this board).
However, this is a simple installation (depending on how handy you are).
As with everything else, it requires the bumper and air-filter housing removal.
The entire engine bay is a tight squeeze, so a bit of patience is required.
I for one would prefer a car that drives properly, as opposed to having a dreadful driving experience with a warranty.
Given that Porsche will not acknowledge the problem, what other options do we have?
Old Oct 23, 2015 | 08:39 AM
  #521
runner1021's Avatar
Originally Posted by beemer guy
I have several thoughts. OT, I apologize.[LIST][*]Has anyone ever done a before and after dyno on this item to prove the 15 horsepower increase?[*]If it were really that easy (a modified plenum) to get another 15 horses, wouldn't Porsche have already done it?
I'm at the point where I'd gladly accept a 15 HP decrease if it completely cured the stumble.
Old Oct 23, 2015 | 08:53 AM
  #522
dux's Avatar
dux
Right there with you...
Old Oct 23, 2015 | 08:58 AM
  #523
runner1021's Avatar
I wonder how this jives with the fact that stumble temporarily disappears after a re-flash or a battery disconnect? Are the two in any way related?
Old Oct 23, 2015 | 09:01 AM
  #524
dux's Avatar
dux
Georgefu did mention that his stumble always returned shortly after re-flashes and dealer fixes.
Exact same problem I've had on numerous occasions..
Old Oct 23, 2015 | 09:15 AM
  #525
runner1021's Avatar
Curious as to how a hardware (plenum) swap can fix an apparent software issue (assuming the plenum swap doesn't require a re-flash).
