Engine stumble/hesitation around 2500 RPM?
Old Sep 10, 2015 | 01:14 PM
  #481
stealthboy's Avatar
stealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud of
I'm thinking of all the possible items to investigate. If anyone wants to help compile a list, please add on. I'd like to have a list of sensors and items that are relatively easy to replace to rule out potential faults.
- Throttle position sensor
- Throttle body
- O2 sensors
- High-pressure fuel pump
- Spark plugs
- Fuel filter
- Ignition coils
I'm sure there are all sorts of other sensors... Those who know more please chime in! I'm looking for things that would lead to the appropriate delivery of fuel / spark / air. So that's either a sensor feeding data into the ECU or the delivery mechanism itself. I know there are typical things (spark plugs) but what I need help with are the 991-specific things.
As I start down this path I would like to try to be methodical about it.
Old Sep 10, 2015 | 02:25 PM
  #482
991carreradriver's Avatar
991carreradriver has a spectacular aura about991carreradriver has a spectacular aura about991carreradriver has a spectacular aura about
- Throttle body
- O2 sensors
- Spark plugs
- Fuel filter
- Ignition coils
Have you considered speaking to the folks at GIAC Tuning that have an ECU flash for the both the 3.4 and 3.8 configurations. I understand that the flash is totally reversible. They may be willing to let you try their flash to see if they inadvertently solved this problem. It appears that their engineers have a pretty good handle on the ECU, its control of fuel/air mixture and all the sensors.
If I was in this situation, I would try anything. Just a thought.
Old Sep 14, 2015 | 09:00 AM
  #483
AlbertC4S's Avatar
AlbertC4S is infamous around these parts
I guess Porsche does not want to admit the problem but yet fixed for the 2016 "On models equipped with the PDK transmission, the mode switch has a "Sport Response" button, which pre-conditions the drivetrain for maximum acceleration."
Old Sep 15, 2015 | 05:19 PM
  #484
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Sadly this is not the issue as the stumble does not discriminate between PDK and MT.
Old Sep 15, 2015 | 05:40 PM
  #485
AlbertC4S's Avatar
Was not aware the issue was also in the MT.
Old Sep 16, 2015 | 06:16 AM
  #486
stealthboy's Avatar
I have a 7MT. It's very much an issue.
Old Sep 16, 2015 | 12:46 PM
  #487
tron786's Avatar
tron786 is infamous around these parts
Just to gauge the severity of this problem... how often do you guys experience the stumble? Everyday? Once a week? Once a month?
I've experienced it very infrequently but when it happens it's usually in the worst situation like crossing a busy road.
Old Sep 16, 2015 | 01:03 PM
  #488
runner1021's Avatar
runner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to beholdrunner1021 is a splendid one to behold
For me it's very noticeable 75% of the time in 2nd or 3rd gear transiting 2600 rpm. I'd kill to only have it occur once a month.
Old Sep 16, 2015 | 02:01 PM
  #489
dux's Avatar
dux
Occurs 90% of the time and will consider trading left nut.
Old Sep 16, 2015 | 02:09 PM
  #490
stealthboy's Avatar
Every time I drive the car.
Old Sep 16, 2015 | 02:31 PM
  #491
991C4s's Avatar
991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold
Every day for me, but must noticeable on the first drive in the morning at around 2000 RPM's.
Old Sep 18, 2015 | 01:23 PM
  #492
MagicRat's Avatar
MagicRat has a spectacular aura aboutMagicRat has a spectacular aura about
This sounds grim. I would echo whoever suggested the re-flash. Might just solve the problem. Have't read this thread fully but wonder if Porsche have sorted out the problem on the later 991s. Imagine the only thing they'd have changed would have been software...
Old Sep 18, 2015 | 02:37 PM
  #493
runner1021's Avatar
Interesting point as far as build dates. Anyone with a '14 or later experiencing the problem?
Old Sep 18, 2015 | 03:01 PM
  #494
MagicRat's Avatar
Mine's a '15 GTS. 5,500 miles and no engine issues so far.
Anyone else?
Old Sep 19, 2015 | 04:54 AM
  #495
dux's Avatar
dux
Yes, a couple of '14 owners also developed the problem.
See link to survey results.
https://www.6speedonline.com/forums/...y-results.html
