Help Porsche Easy Entry and Drive
Old Apr 24, 2013 | 08:51 PM
fixedupw203's Avatar
fixedupw203 is infamous around these parts
Hey guys,
I dropped off my car for service and they took our the dummy car. They forgot to put it back in and had them do it before I left but didn't take a close look until I left. I believe a small piece from it may be missing.
Can someone post a close up of the area the dummy key is inserted in or point me in the right direction?
thanks in advance
Old Apr 25, 2013 | 07:52 AM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Can you post a pic of what you are referring to as "missing".
It is literally just a cheap piece of plastic that replaces the key itself.
Are you referring to the ignition switch (barrel) itself?
Old Apr 25, 2013 | 08:14 AM
PorscheCrazy's Avatar
That "cheap piece of plastic" probably costs $50 to replace!
Old Apr 25, 2013 | 10:45 AM
Yes, I will take a picture this evening when I get back.
The dummy key is present and it's inserted into the ignition but there appears to be a small piece missing from the barrel. It's open so to speak and it seems like there is a button (like a reset button) that's visible.
Old Apr 25, 2013 | 10:46 AM
Anyone know where I can see a closeup of it or can someone post a picture of theirs?
Old Apr 25, 2013 | 11:10 AM
pyramid's Avatar
pyramid has much to be proud ofpyramid has much to be proud ofpyramid has much to be proud ofpyramid has much to be proud ofpyramid has much to be proud ofpyramid has much to be proud ofpyramid has much to be proud ofpyramid has much to be proud of
Yes, the very small rectangle cover is missing if you could see that kind of reset button. See your owners manual, the picture should be there.
In order to take out dummy key, you need to pull the cover out and then push the reset button to release the lock. You use an L shape metal pin to do all that. The pin is located behind fuse cover on your footwell.
Old Apr 25, 2013 | 11:47 AM
Yep, sounds like they forgot to put the cover back on.
Old Apr 25, 2013 | 01:24 PM
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
I'll post a picture tonight if nobody else does.
Old Apr 25, 2013 | 03:24 PM
dux's Avatar
dux
With my dummy key in place there are no visible holes.
Are you referring to this little cover to the left?
Old Apr 25, 2013 | 04:39 PM
mtony's Avatar
Here you go...
Old Apr 25, 2013 | 06:31 PM
Thank you MTONY! Spoke to my service advisor and will have to stop in tomorrow to have this little piece reinstalled unfortunately.
joseph_number1
Jul 19, 2018 05:45 PM
MAcarbon
Mar 6, 2017 08:16 AM
MurderedTurbo
Aug 28, 2015 09:06 AM
ppwchiang
Aug 20, 2015 10:28 AM
MAcarbon
Aug 19, 2015 04:52 PM
