Gravel/Sand sound under car
Old Mar 10, 2014 | 06:06 AM
dshurett's Avatar
dshurett is just really nicedshurett is just really nicedshurett is just really nicedshurett is just really nicedshurett is just really nice
I have noticed driving my car over sand/gravel in the road way that it makes an awful sound as the debris hits the underside of the car. Never heard this in any other vehicle or my 997.2. Is this something normal with the 991 or did they forget some padding?
Old Mar 10, 2014 | 06:38 AM
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
Normal. There's no wheel liner in the back so all the sand rocks that get kicked up hit the mufflers etc.
carcam's Avatar
carcam is infamous around these parts
Unfortunately it's normal for every 991 including turbo. It's very annoying. If you look under the rear wheel wells, it's mostly metal, little plastic, no undercoating and the entire back half has nothing except the metal engine stuff and mufflers. Maybe to reduce weight or enhance service access when the bumper is removed? It was the first thing I noticed dropping off my 997 and driving out with my 991.
Old Mar 10, 2014 | 06:58 AM
97c2s993's Avatar
97c2s993 is infamous around these parts
Probably to enhance cooling too I would think...but yeah, it's a bit of a surprising and disturbing sound when it happens...I still haven't gotten used to it
Old Mar 10, 2014 | 08:48 AM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
It's probably my only complaint with the car so far. Drives me nuts. It ruins the "high end" experience somewhat for me.
I don't know why Porsche doesn't use the "fuzzy" wheel well liners like most other manufacturers. It dramatically cuts down on noise.
I considered putting Dynamat on the back of the plastic liners but it's expensive and heavy. I also considered the spray on undercoating/sound deadening on the outside of the plastic liner.
Unfortunately, I think most of the noise, certainly the worst, is from the open mufflers.
I'm still considering options. Gotta be something we can do.
Old Mar 10, 2014 | 08:59 AM
mas8002mi's Avatar
mas8002mi is infamous around these parts
u shld hear that noise in my GTR...... it is much worse than my 991-S......
Old Mar 10, 2014 | 09:02 AM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
Weld some brackets on those side mufflers and add fuzzy wheel well liners.
Buy a liner from x car and cut to fit.
You could remove them for track days, to restore cooling.
Old Mar 10, 2014 | 04:45 PM
chuckbdc's Avatar
chuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud of
Keep this thread up and soon there will be a configurator option for leather or alcantara wheel liners, with deviated stitching to match the interior.......
Old Mar 10, 2014 | 04:51 PM
Zelig's Avatar
Zelig is infamous around these parts
I got a small pebble caught in the rear suspension that was causing a bad noise going over bumps. I suspect this lack of lining was the root cause of the pebble getting way up into my suspension. Dealer replaced struts and re-torqued the suspension first after they got the Porsche Factory Tech involved but finally found a burnished rock that was the fix.
Hope it doesn't happen again. Car was in the shop for almost two weeks while they sorted this out with PCNA.
Old Mar 10, 2014 | 05:32 PM
kobett's Avatar
kobett is infamous around these parts
Been experiencing this a lot too. They've been doing construction on the street I work at and it's definitely unpleasant to drive on. I literally go a quarter mile down the road at 10 mph and you can still hear rocks hit the underbody every second.
Old Mar 10, 2014 | 05:43 PM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
Sticky tires
Old Mar 10, 2014 | 06:07 PM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
Haaa classic. Porsche Exclusive option
Old Mar 10, 2014 | 06:27 PM
BlackSpeed's Avatar
BlackSpeed is infamous around these partsBlackSpeed is infamous around these parts
the gravel/stones noise is something I noticed right away and it is unsettling. I always cringe a little because I know the car is getting pelted. It's especially bad right now after the winter sand/debris all over the road. I go about 5mph out of my neighborhood right now because I can't stand the sound!
This is horrific and horrible to hear. I wish there was an option for fixing this, but I suspect anything put into the wheel wells would melt or possibly interfere with the car in some way--and frankly it's not worth it.
Arghh, another reason to wish for summer, clean roads!
Old Mar 10, 2014 | 06:29 PM
Dilligaf's Avatar
Dilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to all
This was so funny started laughing in the airport, then stopped realizing it could happen.
Old Mar 10, 2014 | 07:02 PM
naples991's Avatar
naples991 is infamous around these parts
3M the muffler Seriously I noticed this on my test drive.
