Ctek battery charges.
Old Jun 22, 2014 | 02:24 PM
Dilligaf's Avatar
Dilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to all
I am looking at getting a ctek battery charger, leaning toward the multi 4.3 as I believe it is the same you get from Porsche, but what I do not see is what accessories comes with the charger. On the web site, it looks like there is one branded with the Barrett Jackson name that the picture shows clamps and terminal eyelets.
Does anyone know what if any connection accessories comes with their chargers?
Old Jun 22, 2014 | 04:22 PM
Dadz911's Avatar
Dadz911 is infamous around these parts
With my last one I got from Porsche it came with the clamps, the piece you can hook on the battery and the piece that plugs into the power port, which is the one I use, if I ever use it. I normally try to put it on one of the 3 cars if it has not been driven in a week or so. By using the power plug option you don't have to worry about getting extra ends to attach to the battery. The only PITA part is that your power port has to be able to supply power when the car is off in order to accept power going back into it. So if it shuts off with the car, you can't use it to charge the car. On the Porsche I believe the one that doesn't shut off with the car is the one on the passenger side where your left leg would be.
Old Jun 22, 2014 | 05:56 PM
mdk888's Avatar
mdk888 is a jewel in the roughmdk888 is a jewel in the roughmdk888 is a jewel in the roughmdk888 is a jewel in the rough
I got my ctek charger from amazon. It came with the clamp style and some other connect (small loop). I bought the cigarette adapter separately and use that on the connector inside the armrest console in the middle. I believe it works since I see the light going to green after a night's charge. But then who knows, maybe I'm doing it wrong as the other post mentioned it needs to be the one by your leg. I don't have the smoking package btw, not sure if that matters and I don't lock the car when its trickling either.
Charger:
Amazon.com: CTEK Multi US 3300 12-Volt Smart Battery Charger: Automotive Amazon.com: CTEK Multi US 3300 12-Volt Smart Battery Charger: Automotive
Cigarette plug adapter:
Amazon.com: CTEK 56-263 Comfort Connect Cig Plug: Automotive Amazon.com: CTEK 56-263 Comfort Connect Cig Plug: Automotive
Old Jun 22, 2014 | 06:01 PM
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
I have the Porsche one. Works great.
Old Jun 22, 2014 | 06:36 PM
RichardC's Avatar
RichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of light
I have the Porsche. Dealership threw it in a gift bag when I got the car. It doesn't have any clamps for the battery. Just the 12v plug.
Richard
Old Jun 22, 2014 | 06:53 PM
Dilligaf's Avatar
Thanks all, just ordered as the price was good and got free shipping, I appreciate the responses.
Old Jun 22, 2014 | 07:37 PM
TSpyder's Avatar
TSpyder is a jewel in the roughTSpyder is a jewel in the roughTSpyder is a jewel in the roughTSpyder is a jewel in the rough
Charger:
That's exactly the combo I bought off of amzn several yrs ago for my 23 yo NSX which frequently sits for long spells between drives. I've used the CTEK on the 991 only once when I was out of the country for a few wks. Can't recall whether I plugged it into the foot-well or smoker's pkg outlet, but it kept the battery topped up fine.
Spyder
Old Jun 22, 2014 | 08:38 PM
Robsc2s's Avatar
Robsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to behold
Ctek 7002 with outlet adapter; passenger side outlet; door shut and car locked all winter. No problems.
Old Jun 23, 2014 | 08:45 AM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
On my car, 2013 C2S Cab the cigarette lighter (car has smoker's package) is always hot so I plug the Porsche version of the CTek in there.
Old Jun 23, 2014 | 09:25 AM
Go123's Avatar
Go123 has a spectacular aura aboutGo123 has a spectacular aura about
You can also use the direct connect and always have the plug at the ready. Would be useful if the battery goes dead and you can plug in from the hood area easily.
https://www.6speedonline.com/forums/...ml#post3937422
Old Jun 23, 2014 | 09:26 AM
scatkins's Avatar
scatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond repute
I just received the 7002 from Amazon and was disappointed that it didn't have the cig/power port adapter..
Did you order that separately?
Old Jun 23, 2014 | 11:50 AM
Robsc2s's Avatar
yes along with ctek comfort indicator extension
Old Jun 23, 2014 | 05:49 PM
scatkins's Avatar
Yeah, I just ordered those both..
Not sure if I need the extension, but I didn't want to have to run the 115VAC cord (which is kinda a large diameter) through the door jamb or under the frunk hood..
I wasn't exactly sure if the cigarette adapter would work properly with the 7002, since it has a pretty high current output capability that probably exceeds the fuse on the car's cigarette adapter. But there must be something in line with the CTEK that regulates/limits that when the cig adapter is in use (instead of the battery clips or direct connection).
We will see I guess how well it works.
Old Jun 24, 2014 | 09:13 AM
Robsc2s's Avatar
no issues over winter and car started right up- doubt you'll have that type of weather in So Cal
Old Jun 24, 2014 | 09:16 AM
Snowczar's Avatar
No issue with mine in either the 991 or 996 TT cigarette lighter connections.
