IPOD Problems
Old Aug 11, 2014 | 06:01 PM
Zelig's Avatar
Zelig is infamous around these parts
IPOD Problems
My Burmester amp was replaced when the car was about a month old because I lost all functionality (sound, phone, the works). Now about a year later, I noticed when I switch to IPOD, it was taking too long to start up in that mode. Today it wouldn't go switch to IPOD at all. I restarted the car and that seemed to resolve it. At first I had the same error message, something to the effect of "no track recognized" but then the IPOD functionality kicked in and was OK.
Anyone else have a problem with their IPODS who have Burmester or have IPODS with the BOSE or Base units?
Hopefully it will be a reflash. The car was in the shop 2-3 weeks for the parts last time.
Old Aug 12, 2014 | 05:52 AM
jster's Avatar
jster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud ofjster has much to be proud of
I received this message the other day and, as you mentioned, the ipod then went ahead and resumed from where it had stopped. I find that if I open some other door first (put something in the frunk, golf clubs on passenger side, etc.) and then get in the ipod starts up immediately. If I get into the driver side first and the car has gone to sleep (say overnight), ipod startup can be a bit. I think all this is normal and, at least for me, this behavior has been consistent from day one.
Old Aug 13, 2014 | 01:16 AM
wysiwyg's Avatar
wysiwyg is infamous around these parts
I've never had rock solid iPod integration with any in-car iPod interface. Had intermittent problems with an E60 BMW, an E70 BMW, 987.2 Cayman S (Bose), a Panamera (Burmeister), a 981 Boxster S (Bose) and now a 991 (Bose). The problems aren't serious though... one in maybe 15/20 times the iPod is not recognised or it's recognised but the content doesn't pass through. Usually if I unplug it and replug it in, it works fine. There was one time in the 987.2 where a software update for PCM worked for a short while, but otherwise it's been hit or miss and I couldn't care less any more to jump through hoops and try to make it flawless.
Old Aug 13, 2014 | 02:23 AM
mrchua's Avatar
mrchua is infamous around these parts
Usually its the ipod cable thats the problem. Try changing it.
Old Aug 14, 2014 | 11:33 AM
Zelig's Avatar
Much appreciated. I tried the cable but that didn't work. Car is going soon and service manager is going to check it. The Burmester amp was replaced but he said there are "interfaces" that can be also an issue.
Old Aug 17, 2014 | 02:08 PM
hdawg's Avatar
hdawg is infamous around these parts
I had a similar problem , latest ipod software update helped. Have far fewer issues now. Worth a shot.
Old Aug 17, 2014 | 04:59 PM
Zelig's Avatar
Much appreciated. Car is going in tomorrow. Will ask about it then.
Old Aug 22, 2014 | 11:05 AM
jster's Avatar
This bug must be a new virus transmitted just by reading this thread. Today it happened to me and, for the first time, would not go away. Basically the current song would play but none of the Ipod info (playlist, tracks, etc.) was selectable (white'd/grey'd out). Turn the car off and then on; no change. Reset the PCM; no change. Switch to another source; no change. Unplug/replug Ipod; no change. Completely pull Ipod and do an Ipod hard reset; it works correctly again! YMMV.
Old Aug 22, 2014 | 11:43 AM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Had a similar problem with a different vehicle.
Ended up being the outdated IOS on the ipod.
Old Aug 22, 2014 | 01:12 PM
HotHonda's Avatar
HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !
Reset of ipod generally cures problems for me (multiple cars).
Old Aug 24, 2014 | 11:26 AM
Zelig's Avatar
Agree with HotHonda. Dealer found the error, reset my IPOD and that did the trick.
hdc4
Bentley
11
Jan 6, 2019 07:17 AM
Sleestak
Oct 7, 2015 02:12 PM
ELMEL
Sep 28, 2015 01:12 PM
troyztoyz609
Sep 17, 2015 06:09 AM
