What are common causes of buzzing sound on the left?
Old Sep 24, 2014 | 03:03 PM
RichardC's Avatar
RichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of lightRichardC is a glorious beacon of light
I'm taking my car in next week to find a buzzing sound on the left driver's side. I'd like to maybe point the service guys in the right direction if someone has had this fixed before.
1. It is more of a buzzing sound and not a rattle from the door area.
2. It happens on accelaration mainly.
3. When the weather was warmer this summer, it went away.
If someone has been able to narrow this down, I'd appreciate any help.
Thanks in advance.
Richard
Old Sep 24, 2014 | 03:19 PM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
If it's right by your left ear it's probably your seat-belt tensioner cover.
On warm days it expands - hence no rattles.
Do a search on this forum for "rattles" or take a look in the DIY section (with pictures), grab some felt-tape and spare yourself a trip to the dealer.
Old Sep 24, 2014 | 03:34 PM
dux's Avatar
dux
Old Sep 24, 2014 | 03:36 PM
RichardC's Avatar
Thanks, I'll suggest that as one possibility, but it sounds like it is more on the left and ahead of me. Maybe door handle, or trim, but I'm not sure.
Richard
Old Sep 24, 2014 | 06:10 PM
AlecS's Avatar
AlecS has a spectacular aura aboutAlecS has a spectacular aura about
Perfect thread for me today. I've been getting that buzzing sound too over uneven pavement more and more. It was just starting drive me nuts today. Left side but for me clearly in the back. Then while driving I reached back to the seat belt coupler right behind me and gently pushed it away from the leather. Sort of gave it a little room. IT WORKED! Buzzing gone. Nice rattle free car again.
You might want to check that.
Alec
Old Sep 24, 2014 | 07:38 PM
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
I've had two buzzing sounds on the left. One was the lower front part of the door panel and the other was the headliner right where the A pillar meets the headliner.
Old Sep 24, 2014 | 08:28 PM
toddcc1's Avatar
toddcc1 is infamous around these partstoddcc1 is infamous around these parts
I have a "rubbing" sound occurring in the front left. Sounds like two pieces of plastic rubbing against one another. The fix for him was that the seals around the gas tank shift out of place, which creates the squeaking in the firewall area. You would think it would be heard further on the right, but it's the left.
Forum members post on same...
https://www.6speedonline.com/forums/...urnal-149.html
Old Sep 25, 2014 | 05:03 AM
97c2s993's Avatar
97c2s993 is infamous around these parts
Do you happen to also have the buzz when playing music with deeper bass, the buzz intensifying with the bass thumps(?) and not at obnoxiously high volume? I found that if I press my left knee or hand on the handle that runs above the speaker (against the door) it suppressed the buzz, indicating to me a lack of tightness of fit or fastening of the door panel at around that spot - making me think the noise is coming from either where the speaker is located (the grille that covers it), or perhaps the window/mirror switch housing bezel.
Try pressing where I mention and see if it helps. I haven't taken my car in yet for it.
Old Sep 27, 2014 | 12:00 PM
RichardC's Avatar
I had a buzzing sound in the speakers when deep bass was playing that has been fixed. They found electrical wiring causing a rattle and wrapped it with felt tape and found the upper corner of the inner door trim didn't have enough pressure from the trim clips and added felt tape there as well. That fixed the problem with deep bass, although I rarely listen to music in the car. It is the buzzing on acceleration that is driving me crazy right now.
Hopefully what they found in my car helps for you.
Richard
Old Oct 2, 2014 | 07:29 PM
RichardC's Avatar
I just wanted to report in. I took my car into the dealer for the buzzing coming from the left driver's side on acceleration. The dealer found it was coming from the driver side seat memory switch bank. They removed the door panel, removed switch bank, and added sound insulation to the switch bank and contact points on the door. The buzzing sound is now gone on acceleration.
Hope this helps if anyone else has a similar problem and wants to point the dealer to it.
Richard
MAcarbon
Mar 6, 2017 08:16 AM
MAcarbon
Aug 24, 2015 03:26 PM
MAcarbon
Aug 20, 2015 03:02 PM
MAcarbon
Aug 19, 2015 06:22 PM
MAcarbon
Aug 19, 2015 04:52 PM
