2013 911 s tapping sound in engine when car is first started
Old Nov 14, 2015 | 06:35 PM
rgreenberg's Avatar
rgreenberg is infamous around these parts
My 2012.5 991 S has a tapping sound when I started up today and it was only 50 degrees in my garage. I never had that happen in the past three years.
Anyone have any advice they can tell me. IT ONLY HAPPENS WHEN ITS FIRST STARTED IN THE COLD THEN STOPS AFTER ABOUT 5 mins
Old Nov 15, 2015 | 07:15 AM
chuckbdc's Avatar
chuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud of
A "tapping sound" is a pretty general description- could be a lot of things. One possibility is DFI.
My 2012.5 C2S sometimes starts with tappet ticking sounds like my 911SC (with solid lifters) made when it needed a valve adjustment. I took it to the dealer the day after I got the car, in February 2012. They advised it was the fuel injectors of the high pressure direct fuel injection (DFI) and perfectly normal. Whatever, it has had no issues.
Old Nov 15, 2015 | 07:31 AM
2001f4s's Avatar
2001f4s is infamous around these parts
My 2013 991 makes the same sound here in Chicago in the cold. My 2007 Cayman (X2) also made the sound. Seems to disappear after a few minutes. No issues here.
Old Nov 15, 2015 | 09:23 AM
dhill911's Avatar
dhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond repute
I believe it is normal. Mine does it too in cold temperatures. It will also do when it sits for a long time without running.
Old Nov 15, 2015 | 12:06 PM
stealthboy's Avatar
stealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud of
Hydraulic lifters had drained and needed to pressurize. I had the same thing happen twice after sitting for a while. Discussed at length with my dealer's service manager and nothing was out of the ordinary. It's certainly quite a racket for five minutes!
The fuel injector sound is a different tapping. That's more "normal" and is because the injectors are closing back with such force.
Old Nov 16, 2015 | 11:25 PM
Fester's Avatar
Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !
Sounds normal.
timwu12
Cayenne 955/957
Nov 13, 2015 12:57 AM
thackl
Nov 9, 2015 04:53 PM
e8_pack
Nov 5, 2015 10:52 PM
saphgreyc63
Oct 30, 2015 11:21 PM
PelicanParts.com
Oct 20, 2015 03:15 PM
