991 cabriolet window problem
I PUT MY TOP down today and the right rear window does not respond to come up when closing top. anyone else with this issue and at least offer a suggestion?
I'm aware this was originally posted years ago, but I'm having the same problem now. The solution was: It just needs adjusting. Is this something I can do, or do I need to take it to a dealer? Thanx
Dealer is your best bet. They will at least tell you what the issue is and warranty the work they do using genuine parts. If it's just an adjustment, it should only cost 1hr labor.
Best of Luck!
Best of Luck!
