DIY 991 Carrera S Rear Brake Pad Replacement
DIY 991 Carrera S Front Brake Pad Replacement was GREAT. I am trying to find same information for DIY 991 Carrera S Rear Brakes, and how to disconnect rear sensor pad connections. 2014 Carrera S.
Porsche Crazy: I attempted to add a photo, but can't get it to size correctly. I can't figure out how to disconnect the rear brake pad sensors. I have removed caliper bolts and can get the the brake pads, but they are attached to the pad sensor and I don't know how to disconnect. How do I get to the sensor to disconnect?
https://www.6speedonline.com/forums/...placement.html
Porsche Crazy: Thanks for your assistance. I got the back brake pads replaced. I did not replace the brake sensors. How do I get the dash board display warning of brake pad replacement to turn off?
Thanks.
Thanks.
You can buy an obd scanner to get rid of the light -- the scanner is also good for getting rid of oil service lights and service reminders. You can also clip off the end of the sensors and solder or twist together the exposed wire ends (and secure with an appropriate connector or electrical tape) and zip tie them out of the way. You will re-establish the circuit continuity in that way, and get rid of the light.
If you removed them without harm , you can plug them back in and twist tie them out of the way to eliminate the warning light without having them in the pad ( and your way).
