993 Last generation normally aspirated aircooled Porsche 911. Community includes the C2, C2s, C4, Targa, C4s and cabriolet discussion.
993 Cabriolet Latch Motor
Old May 3, 2022 | 11:27 AM
Markwhit78's Avatar
Markwhit78 has much to be proud ofMarkwhit78 has much to be proud ofMarkwhit78 has much to be proud ofMarkwhit78 has much to be proud ofMarkwhit78 has much to be proud ofMarkwhit78 has much to be proud ofMarkwhit78 has much to be proud ofMarkwhit78 has much to be proud of
Hi all,
I recently replaced the right-hand convertible top latch motor. The old motor was working intermittently, or more specifically, it would on occasion not activate when trying to open the top. There was some play in the latch mechanism versus the left motor, and it seemed a common problem was a broken tooth in the gears inside the motor. My aim then was to replace the motor to have the top operating pronto for this season, and get to replacing the gearing on the fussy motor when I could devote time and have a spare on hand. However, when I opened the case of the fussy motor's mechanism, I found that the gears are completely intact, everything was properly greased, and the micro switch seemed to be getting good contact.
I've tested all of the other switches along the convertible top: limit switches, micro switches in the main motor. Everything seems to operate as it should at least while I'm testing them.
Is the latch motor just going bad (hence the play)? Or is there a misalignment in the top that I need to investigate? Something else? Looking for any suggestions so that the top continues working as it should and so that I might fix up the now (hopefully) spare motor.
Thanks all!!
Original RH convertible top latching motor
Old Nov 8, 2022 | 01:42 PM
Gelange's Avatar
Gelange is infamous around these parts
Top latch not releasing
I have the same issue. I could lower top a few times then latch wouldn’t release. Forced to spend way too much time trying to get a screw driver on the screw to manually turn the gear. Everything I read pointed to broken tooth was the problem. However, when I opened the latch, the gears are in good order. Sure would like to find out how to fix this problem.
Old Jan 2, 2023 | 09:06 AM
white comet's Avatar
5 Year Member
white comet is infamous around these parts
vertex will rebuild the motor and return it to new operating condition........
jsg00d31
Dec 1, 2022 03:30 PM
red911
911
Jun 7, 2018 03:28 PM
Boby305
Nov 5, 2015 07:19 PM
tt91185
993 Turbo
Oct 3, 2014 12:46 PM
mikesk3
993
Aug 26, 2009 04:12 AM
