Replacing a Fog Lamp
Old Aug 17, 2003 | 10:56 PM
EM 996 GTS's Avatar
EM 996 GTS is infamous around these parts
My left fog lamp died a few days ago... I called my service advisor and he told me that it will take a couple hours to take out the headlamp assembly. (issit really?!) I know it should be free(maybe...), but I dont want to go up the ramp at the dealership if its not necessary, because it will make damage to the Carbon Lip.
and my bodyshop are fully booked up.
Is this (replacing the broken fuse fog light) possible to do it by yourself @ home? or is there a special tools required? Does anyone ever done it before?
Fog lights are = H7 right?
Thanks in advance,
Endra
Old Aug 17, 2003 | 11:20 PM
oak's Avatar
oak
It takes 5 to 10 min max. Not even worth driving down to the dealership. Check the manual?
Old Aug 18, 2003 | 12:15 AM
Tool Pants's Avatar
Tool Pants is infamous around these parts
The tool is in your kit. Takes a few minutes. Jeff
Old Aug 18, 2003 | 12:51 AM
msindi's Avatar
Its actually H3!! Get the PIAA Extreme white 55W=85W while youre at it - check my sig
Old Aug 18, 2003 | 01:00 AM
EM 996 GTS's Avatar
Thank you guys...
I haven't check the manuals yet, but doing that first thing tomrrow morning.
Endra
Old Aug 18, 2003 | 01:05 AM
EM 996 GTS's Avatar
That's not a bad idea... I'll look around for PIAA bulbs tomorrow.
but, is there any problem changing them into higher watt bulbs?
because on MercedesBenz (CL and S), if the watt is higher than the standart ones, it'll triggered the computer sensor. The "check lamp" message will appear on the dash after you turn on the lights...
Thanks,
Endra
Old Aug 18, 2003 | 12:38 PM
msindi's Avatar
The way the PIAA works is that the ones I have only draw 55W (like your stock) but their output is equivalent to the brightness of an 85W...Also, the Extreme white matches the xenons PERFECTLY!!
I wouldnt put a higher wattage bulb anyway as I know from experience (friend's car!!) that over time your headlight housing can melt!!
Old Aug 18, 2003 | 12:42 PM
EM 996 GTS's Avatar
Thanks for the info...
I have a quick question. I got my fog bulbs out... do you replace the whole thing? (see attachment) and its H3
Yes, and I also learn that before... that higher watt will melt the housing. I ended up buying another one.
thanks again,
Endra
Old Aug 18, 2003 | 12:44 PM
msindi's Avatar
Yup - you just snap the new bulb in - secure it with that wierd clicking latch and connect the cable - voila!!
Make sure you use a glove or or something as you are not supposed to touch bulbs with your hands as the oil from your skin can heat up later and cause damage...Besides fingerprints are nasty...LOL
Old Aug 18, 2003 | 01:19 PM
sharkster's Avatar
msindi.. you are without a doubt the head lamp expert
RallyBird
Oct 7, 2015 01:20 PM
spreeon
Aug 27, 2015 08:14 PM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
