Video of my Dyno Run as promised.
Old May 17, 2004 | 09:46 AM
Orli930's Avatar
Orli930 is infamous around these parts
Proof is in the Dyno. 476rwhp. I will be reinstalling cats as per the performance guru's of this board. I will redyno before and after the EVO stage 4 gt mods are installed
GIAC Stage 4 Dyno Run(RIGHT CLICK AND SAVE AS!!!)
Old May 17, 2004 | 10:03 AM
KPV's Avatar
KPV
Pretty cool video!
Evan is getting very good with his editing skills I see!!
Old May 17, 2004 | 10:06 AM
Orli930's Avatar
Performance Guru's please "Chime in" I would like your opinions.
Old May 17, 2004 | 10:13 AM
DJ's Avatar
DJ
Very cool
Old May 17, 2004 | 10:37 AM
cjv's Avatar
cjv
Moderator
Orli,
What was holding your car on the dyno? The two rear binders looked like they were loose. The car looked like it was moving around way to much.
Old May 17, 2004 | 10:38 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
Cool
If the front drive shafts are disconnected for the test, does that give a higher value since all of the power goes to the rear?
Old May 17, 2004 | 10:48 AM
cjv's Avatar
cjv
Moderator
There are alot of ways to get higher numbers. Simply calibrating the run using different standards will give different numbers. Yes, a 2wd dyno gives higher numbers than an awd dyno. The awd dyno also uses higher conversion factors than a 2wd dyno. Generally a 2wd dyno uses a 15% factor while an awd dyno uses a 25% factors. Using higher factors generally just inflates the bottom line. Also don't confuse these conversion factors for fwhp with SAE standard, SAE 1990 Revision, DIN or uncorrected. In addition, conducting the dyno run in different gears (generally 4th or 5th) will produce different figures.
If you are going to compare dyno numbers the set up must be the same, otherwise you are wasting your time. When comparing you own dyno runs, use the same dyno and set up each time if you want your information to have any value.
Old May 17, 2004 | 10:50 AM
Orli930's Avatar
Two chains were holding the car down. Do you think this Dyno was run was not performed correctly?
Old May 17, 2004 | 10:59 AM
cjv's Avatar
cjv
Moderator
When you have movement you have slippage and loss of power. Correctly When we dyno KA we don't rev up each gear. We shift from first to 5th and then start the numbers at about 2100 to 2300 rpm's in fifth gear and go to wot to 7400 rpm's.
I didn't see a probe in the exhaust so I am assuming there were no afr's recorded. What conversion factor was the dyno's computer set to convert to, SAE Standard, SAE Revised, DIN or uncorrected?
The fans for the intercoolers were fairly small and I didn't see a fan for the radiator up front. What was your water temperature reading?
Old May 17, 2004 | 11:13 AM
Orli930's Avatar
Chad, you just answered my question! This dyno run was performed incorrectly.
Champion Motorsports will have their 4 wheel dyno up and running by the end of June.
Old May 17, 2004 | 11:37 AM
PorschePhd's Avatar
Lose the chains and use real straps that can be pulled down. The chains are causing way to much movement and the car will loose rated power on the dyno. That energy is every where, but to the rollers. The more power you make the worse the loss will be.
Old May 17, 2004 | 12:33 PM
Dabum's Avatar
Dabum is infamous around these parts
I noticed it did move alot aswell, thought it was about to fly off at that one point
Car sounds great though! And 477bhp is really good.
Old May 17, 2004 | 07:34 PM
CAPTLST's Avatar
CAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond repute
Nice job with the editing Evan!!!!
Eric
Old May 18, 2004 | 04:02 AM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Awesome nice video!
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Zero911
Aug 24, 2015 06:51 PM
Fabspeed Motorsport
Aug 18, 2015 03:24 PM
Fabspeed Motorsport
NY Tri State
Aug 18, 2015 03:22 PM
