Best launch technique
Old Oct 21, 2007 | 03:53 PM
snapscan's Avatar
snapscan is infamous around these parts
I need a couple of pointers...any suggestions?
Old Oct 21, 2007 | 04:06 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Depends on what level you're at and what kind of clutch, but generally I've found that 4000rpm hard clutch slip is the way to go. Make sure your tire pressures are low (25psi). Get progressive on the gas through first, then WOT the rest of the way.
Others have had better luck with a clutch drop, but in my experience all I have seen doing that is tons of really ugly wheel hop.
Good luck
Old Oct 21, 2007 | 04:15 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
i would like to know this as well.
Old Oct 21, 2007 | 04:23 PM
S-351's Avatar
S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !
Good luck
You are so correct...I "fan" the clutch on the launch too.
Old Oct 21, 2007 | 04:44 PM
tom kerr's Avatar
your cars must hate you guys!!
Old Oct 21, 2007 | 05:15 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
I agree with Jimmer and S-351. Feather it - anywhere from 3,000 RPM's up. I go a little easier ...at about 3,000 RPM's.
Old Oct 21, 2007 | 06:00 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
Old Oct 21, 2007 | 06:01 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Don't mean to sound dumb, but what exactly do you all mean by feather? Like ride the clutch out at 3k? What I've always done is ride the clutch out till it grabs a little then dump it.
Old Oct 21, 2007 | 07:09 PM
John D's Avatar
Powell,
You description is what I was getting at...
Old Dec 12, 2007 | 09:59 PM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
whats the difference between a clutch slip and clutch drop?
Old Dec 13, 2007 | 09:00 AM
MidnighTT's Avatar
MidnighTT is infamous around these parts
Clutch slip means that you hold the engine revs at some elevated rpm, say 3000, and let the clutch out until it puts some load on the engine. Ypu hold the pedal at the partial clutch engagement point. You don't let the clutch pedal come all the way out until the car speed has caught up to the engine rpm. This is just a slightly more brutal version of what you do every day pulling away from a dead stop.
Clutch drop means bringing the revs up to the elevated RPM, let's stick with 3000, and then abruptly taking you foot off of the clutch pedal. Some guys slide their foot off the side of the pedal, letting the return spring push the pedal out.
Slipping is very hard on the clutch, dropping is very hard on everything after the clutch.
Jeff
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
7thsign
Dec 12, 2015 07:43 PM
calexand
Nov 5, 2015 01:05 PM
