Disappointement - 04 TT with Evo Programming
Old Oct 28, 2007 | 07:07 PM
forhamilton's Avatar
forhamilton is infamous around these parts
Stage 2. Factory exhaust and turbos. EVO flash, intake, DV and LWFW.
Runs amazing above 2k rpm's. Below about 2200, it sputters, spits and is genuinely pist off. Any ideas?
Old Oct 28, 2007 | 07:11 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Originally Posted by forhamilton
Stage 2. Factory exhaust and turbos. EVO flash, intake and LWFW.
New dv's.
Old Oct 28, 2007 | 07:17 PM
Should have posted earlier. Evo DV. Corrected earlier post.
Old Oct 28, 2007 | 07:18 PM
Sker66's Avatar
Sker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of light
Take it to a reputable tuner!
Gotta pay tp play!!...........but it will be fun when running correctly........cheers ,Gman
Old Oct 28, 2007 | 07:19 PM
Hmmmm. PM me.
Old Oct 28, 2007 | 07:23 PM
A tuner will not help... if he did just a flash then somehting is not right...
maybe a mix up witht he flash.... how does it idle? how about under full boost at 4500 rpms? any stutters?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 28, 2007 | 07:26 PM
Lately it has been idling sporadic. Fine for a few seconds, then starts moving up and down. Between maybe 800 and 1400 rpms. But, not always. Sometimes just fine.
Old Oct 28, 2007 | 07:39 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I would be looking for a boost hose/intake leak somewhere
Old Oct 28, 2007 | 08:11 PM
Yeah you have a boost leak... a hose is loose probably near the intercoolers...
no big deal.
9.66
click to view
Old Oct 28, 2007 | 08:18 PM
landjet's Avatar
Could it be he needs fresh spark plugs?
Old Oct 29, 2007 | 03:52 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
try cleaning the MAF sensor?
Old Oct 29, 2007 | 07:19 AM
Spark plugs are new.
I will check for loose hoses.
Where is the MAF located?
Old Oct 29, 2007 | 08:49 AM
Dan@EVO's Avatar
Dan@EVO is infamous around these parts
Give Mike a call. Considering it started happening recently he can trouble shoot it and get you sorted.
Old Oct 29, 2007 | 10:02 AM
smistry007's Avatar
MAF is located on the left of the engine compartment on the air intake just after the air filter. You will need a "security" torque driver to remove the 2 screws and then just unclip the electrical harness and pull it straight up. Spray it with electrical cleaner, let dry and reinstall.
https://www.6speedonline.com/forums/...ght=maf+change
good luck.
Old Oct 30, 2007 | 11:24 AM
TT Surgeon's Avatar
I prolly wouldn't flash a car with a stock, highly restrictive, exhaust.
