ABS and PSM warning lights suddently came on!!
Old May 24, 2004 | 01:48 AM
John in Norcal's Avatar
John in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to behold
While driving around in town yesterday, my ABS and PSM warning lights suddenly came on. It stayed lit for the duration of the drive but the car did not feel as if something was wrong. After I arrived at my destination I shut the engine off, waited a few seconds and started the car back up and the warning lights were off. I drove around some more for the rest of the day and the lights never came back on and the car felt normal.
Anyone know what could've caused the warning lights to come on? Should I be concerned and take it to the dealer or just forget about it? My car is stock except for Upsolute chip, Evo DVs and Techart exhaust. Thanks in advance for your input.
Old May 24, 2004 | 02:18 AM
msindi's Avatar
SOmetimes if all 4 wheels leave the gorund the two lights will come on
Old May 24, 2004 | 02:36 AM
KPV's Avatar
KPV
A boost leak will also trigger the pair. Check all of your turbo and intercooler hoses as well as the smaller hoses leading to the DV's.
Old May 24, 2004 | 02:42 AM
jro's Avatar
jro
jro is infamous around these parts
John,
Three weeks ago, I had the same situation. However, my ABS/PSM failure lights came back on. I took it to the dealer, and it turned out that one of my front wheel speed sensor had gone bad.
A week later, the ABS/PSM lights were back on. I took the car back to the dealer, and it turned out that one of my front rotors had warped and was completely used up.
The dealer is now doing a front brake job, rotors and pads, and replacing the ABS module. Rotors and pad are non-warranty items.
Old May 24, 2004 | 03:29 AM
sharkster's Avatar
I had that happen with my upsolute chip, the early version but I believe that was just a bug that they fixed?
Old May 24, 2004 | 03:44 AM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
happens to me every couple months too. they've always turn off after the car is turned off and then turned back on.
Old May 24, 2004 | 09:36 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
You might have a bad MAF sensor. I recently had it replaced (under warranty) and so far so good.
Old May 24, 2004 | 09:45 PM
thomasddg's Avatar
thomasddg is infamous around these parts
it seems like i could be alot of reasons why ABS / PSM lights comes on & off...just got my car back from dealer...mine was due to warp rotors...had it change and everything is back to normal
Old May 24, 2004 | 09:49 PM
BCS996TT's Avatar
Yup...the most common occurrences would be bad MAF Sensor, warped rotors, low brake fluid and mismatched tire pressures (according to my service rep)
Old May 25, 2004 | 02:08 AM
Thanks for the input, guys. Sounds like there's a variety of reasons that could trigger the ABS/PSM lights. Would the computer fault codes tell you exactly what is bad or would it have to be diagnosed by the dealer technician?
I guess if something is really bad in my car the lights would come on again. At that point I'll take the car into the dealer and hopefully they won't give me any hassle on the warranty due to my chip/DV/exhaust mods.
Old May 25, 2004 | 04:53 AM
pierre's Avatar
pierre is infamous around these parts
Happened to me a few times at the Nürburgring and on other tracks too... Got a bit nervous the first time, but I'm now just ignoring it.
--Pierre
Old May 25, 2004 | 05:05 AM
BCS996TT's Avatar
Have your dealer read the code. That will tell them what's going wrong.
If your dealer is mod friendly, you will be ok.
Old Jun 5, 2004 | 08:17 AM
Happened again yesterday. Started my car and began backing out of the garage and suddenly the ABS/PSM lights came on. Turned off the ignition, started the car again and the lights were off.
I'm driving the car to Napa and back this week. Do you guys think it's safe? Car drives normal. If it happens again, I'm taking it to the dealer.
Old Jun 5, 2004 | 08:27 AM
Hmmm ....had my Upsolute now for a few months and about 3K miles without any problems. I'll ask my Upsolute rep about it. Tks!
Old Jun 5, 2004 | 08:43 AM
BCS996TT's Avatar
If it were the upsolute, it would trigger at WOT at full boost. That was the main issue with previous versions...too much air overwhelming the MAF sensor. Version 4 fixed this problem.
