Transform your GT700 now!
Old Nov 17, 2007 | 06:14 AM
buddyg's Avatar
Okay now that I have had the Greddy boost controller and 5 bar fpr for a few weeks, I have to say that you MUST do this if you want more power from your GT700!
This thing is wicked fast now and I don't know why it doesn't come like this from Evoms in the first place.
My high boost with race gas is set to 1.5 bar steady and the AFR's are very good. I believe I can go to 1.6 bar and be safe at that point my turbo's are probably maxed out but I should be making close to 690 rwhp!
The one thing I will say is don't do this unless you have upgraded your internals, not worth hurting your motor for an additional 50 rwhp.
I love this thing, I will probably do the Porsche Motorsports gears this winter and be done for a while.
Old Nov 17, 2007 | 11:38 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Buddy dyno that car already!
Old Nov 17, 2007 | 12:57 PM
buddyg's Avatar
I don't have third gear!
Old Nov 17, 2007 | 01:19 PM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
Nice upgrade....even considering it on mine....are you running a egt gauge? If so...where did you mount it...pics? where did you mount the greddy?
Chris
Old Nov 17, 2007 | 02:15 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
yeah, where is everyone mounting the Greddy's?
Old Nov 17, 2007 | 02:36 PM
buddyg's Avatar
Mine is mounted directly under my stereo head unit, and the AFR gauge will be there as well.
Old Nov 17, 2007 | 03:12 PM
jags911tt's Avatar
YOU DON'T NEED IT. DO A 4TH GEAR PULL
Old Nov 17, 2007 | 04:56 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
i'm also curious w/ a dyno. the boost controller probably ramps up on the boost much quicker which makes it feel much faster.
i only push 19.5psi (too lazy to convert) peak, maybe 20-21psi on a good day in 4th or 5th long pull.
do you have a separate boost gauge? or are you using the stock gauge? the stock gauge is *completely* unreliable and i don't believe a word it says (from experience, too slow to catch up...)
if you have a real boost gauge, where is it tapped? where it's tapped will also make a difference in the boost pressure it reads.
and as jags says, you only 4th gear for a dyno pull - do it!
- chuck
Old Nov 17, 2007 | 05:06 PM
buddyg's Avatar
- chuck
The Greddy has a built in boost controller and we plugged in a real time ebd tool to read both banks for afrs. I will see about that dyno.
Old Nov 17, 2007 | 11:09 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
carendt242
The Greddy boost controller is a boost gauge, too. The display on the Greddy shows boost at all times. It is a second boost gauge...
Old Nov 18, 2007 | 02:35 AM
bone_doc s4's Avatar
bone_doc s4 has a spectacular aura aboutbone_doc s4 has a spectacular aura about
BuddyG, nice work!! So you couldnt change your boost settings before? What was your max boost before Greddy BC?
And you're right, why doesnt that kit come with EBC from EVOM? Are you running GT28s? Besides rod and studs, what other internal mods did you do?
thnx
Old Nov 18, 2007 | 09:01 AM
WOODTSTER's Avatar
John,
Where did you get the blank plate of Carbon fibre and the AFR gauge?
Looks really nice!
MK
Old Nov 18, 2007 | 09:40 AM
John D's Avatar
Marty,
I fabricated the Greddy plate from a CD holder and sent it out to be coated (McCarbon). I am going to do the same for the Brockway 920 din plate this winter so that it matches. I have a little work to do to make it sit flush and then I will sent it out to McCarbon for the CF treatment...It's like doing bodywork - just get it flush and sanded flat, then send it out. It will come back perfect and you will never know whats underneath.
The AFR gauge is a brockway 920 with dual bank monitoring (dual bank was by request, but maybe stock now as they were going to introduce it for all models at some point)
http://www.brockwayengineering.com/r920.html
Here is a before picture:
Old Nov 18, 2007 | 09:42 AM
Turbochris's Avatar
Wow, just went to the Brockway enginering website.......Very cool.....do our cars come with wideband O2 sensors... or is this unit truly plug and play for showing EGT's and Boost?
Old Nov 18, 2007 | 09:52 AM
John D's Avatar
Yes, wide band. This is a plug and play - it remains plugged into the OBD2 port and gets all data from the directly from the ECU data. However, EGT and Boost require additional connections and hardware. ECT and IAT are plug and play.
