engine
Old Nov 29, 2007 | 06:29 AM
y996t's Avatar
y996t is infamous around these partsy996t is infamous around these parts
engine
need an answer my left side of the 996t engine it smokes some time, I replace the turbo with a new one an still have the same smoke some time what can it be
Old Nov 29, 2007 | 06:45 AM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
If it just smokes on start up, it will always do that.
Old Nov 29, 2007 | 08:52 AM
Kevinw23's Avatar
Kevinw23 is a jewel in the roughKevinw23 is a jewel in the roughKevinw23 is a jewel in the roughKevinw23 is a jewel in the rough
I get some white smoke at start up, which goes away after 2 minutes or less. Seems to be normal.
Old Nov 29, 2007 | 08:59 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
alot of people are experiencing this.... its quite normal
Old Nov 29, 2007 | 03:17 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Since this engine is a flat, normally opposing head design oil can seep into the cylinder heads and thus, produces the smoke on startup.
Old Nov 29, 2007 | 04:31 PM
y996t's Avatar
its not on start up that it is smokeing, after that goes an come blue smoke an i took the three plugs out an two of then have oil on them, what do you guys think too much boost needs rebuild
Old Nov 29, 2007 | 04:54 PM
ldc's Avatar
ldc
ldc is a jewel in the roughldc is a jewel in the roughldc is a jewel in the rough
FWIW i get smoke if i top off the oil. If i leave it 1 or 2 bars from full I dont get the puff at start up.
dc
Old Nov 29, 2007 | 05:05 PM
y996t's Avatar
did not top off the oil
Old Nov 29, 2007 | 05:14 PM
maybe u have a leak on that side formt he oil feed line that cools the turbo.... or any other leak for that matter. is it all dry?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 29, 2007 | 07:53 PM
y996t's Avatar
yes its all dry, i took out the plugs out 2 of them have oil
Jul 29, 2019 11:13 AM
saline
Oct 7, 2015 07:29 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
