Check engine light came on...
Old Dec 3, 2007 | 07:32 PM
jaykla's Avatar
jaykla is a jewel in the roughjaykla is a jewel in the roughjaykla is a jewel in the rough
I just filled my tank with gas, maybe overfilled it a little and this was after sitting in about 45 min of very slow traffic.
Anyways light comes on and the codes were
P1115 and P1114
what should I do?
Old Dec 3, 2007 | 08:15 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Obviously the first thing is to find out what the codes mean......but periodically I get CELs for PSM and ABS especially after making a hard run. I've found that I just pull over, turn off the engine, restart it and they're gone. I figure that if something is really amiss, they'll come back on. There are a number of guys on this and other forums who experience periodic CEL gremlins....I had a couple that indicated "random misfires" on cylinders 2 and 5. It happened once then.....They just went away and never saw them again. I dont' think you need to run to the Porsche dealership every time a light comes on....if they're repeat events or the lights start flashing, then yes....time for the dealership. You can also go to AutoZone and borrow their reader and read the codes.
Old Dec 3, 2007 | 09:46 PM
jaykla's Avatar
These are the codes that I got off the scan tool. I reset the ECU and the light has gone off. I guess I'll just drive it around and see if it comes back on.
Old Dec 3, 2007 | 10:07 PM
Jay: That's what I do...reset them and go about your business. If they come back and then and hang around, then it's time to do something about them. I'm not a master mechanic, but I think that there are periodic hiccups caused by bad gas, fouled plug or whatever. If you call Porsche they'll scream "emergency" and make you an immediate appointment to come in . I'm not saying ignore it, but you know that they'll charge you to stick it on a PIWIS and find something wrong. I'm not suggesting you ignore potential danger signals...I just dont' believe that every CEL needs a run to the dealership.
Old Dec 3, 2007 | 10:11 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
P1115 and P1114
what should I do?
Jaykla, P1114 is Bank 1 02 sensor ahead of cat not heating properly
P1115 is Bank 1 o2 sensor implausible signal.... you probably need an 02 sensor.
Old Dec 3, 2007 | 10:13 PM
sharkster's Avatar
yup it's the driver's side pre-cat 02... If it's staying off for a while too that's a good indication.
Old Dec 3, 2007 | 10:17 PM
RPM's Avatar
RPM
RPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud of
yeah i just had my mass air flow sensors replaced after my light came on as well...not as cheap of a job as i thought...cost me about 1K at the dealership
Ross
Old Dec 3, 2007 | 10:40 PM
Holy creepin crud Batman....that sounds like a lot of money for that job.
Old Dec 3, 2007 | 10:44 PM
RPM's Avatar
RPM
ahah i know thats what i said...i called two local dealers in Mass and a dealer that i frequent in florida as well and all were in the high 9 hundreds so i figured it was normal..
Old Dec 4, 2007 | 03:20 AM
Speedy996tt's Avatar
Speedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud of
Chuck you are right, obdII cars are so **** that half the time you get a check engine it is absolutely nothing...its a scam to get you to go to the dealer so they can plug in their reader into your obdII port and charge you 100 dollars to read the info off their screen.
Old Dec 4, 2007 | 07:42 AM
wross996TT's Avatar
This is a true case of what we hate about stealers...it takes less than 10 minutes (more like 5) to change a MAF...you can get MAFs for less than $300. It IS a DIY!
Old Dec 4, 2007 | 10:48 AM
Bill: That's what I was thinking....I think you can get the Maf's from Sunset for under $300 and you unplug the harness, take out two screws and reinstall the new ones. Ah the sweet mystique of the Porsche.....make it sound frightfully complex and involved.
Old Dec 4, 2007 | 11:53 AM
RPM's Avatar
RPM
wross i wish i knew that earlier...is there any thread explaining the DIY for the sensors? could you give me a quick and dirty run down? thanks
Ross
Old Dec 4, 2007 | 12:21 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
aint that the truth!
sorry ross, that blows!
Old Dec 4, 2007 | 03:08 PM
wross996TT's Avatar
Ross
Ross, I'll pm you.
