Best uprated brakes for 996 tt
Tom the Stock 6pot GT3 Caliper is more than enough to do the job, what I would do is upgrade rotor, the upgraded rotor lasts 3 times as long over the stock 350mm, trust me I have been through 2 sets, if you look back in this thread I posted a small pic of the Brembo rotors I am using, but sure Dan could sort you out with a rotor to match the 6pot GT3 Caliper.
For those who want to keep stock 18" wheels (TOM) I think Stevo may have the best setup. It appears he has a 2-piece slotted 350mm Brembo rotor mated to the 6 piston GT3 Porsche calipers. There will be Pagid pads off the shelf to fit them.
I had to have custom pads made for the Brembo 6-piston momobloc (which has been out only about a year) BC the only other options I could find off the shelf were Ferodo and I didn't want that. It is my understanding that the same spider cracking problems willl exist with the GT3 rotor as does with the stock ones. Slotted supposedly doesn't do that and therefore lasts longer. I think most are changing drilled rotors due to too much cracking, not BC it has gotten too thin to meet spec.
Oak,
I didn't like what I read about the "soft pedal syndrome" for the Brembo systems hence instilling lack of confidence. Have any others of you running Brembos had a similar problem? Could this be an issue relating to choice of pads rather than the Brembo rotor/caliper assembly?
Oak,
Oak,
A
Yup Stevo has exactly what I want... I want the GT3 caliper with a two piece non-drilled rotor. Anyone know a dealership selling just the calipers?
The rotora setup vivid is selling is an "option", except for the fact that the cailper looks smaller, and who supplies the pads? Also, where do you get replacement rotors from?
I might call coleman racing and see if they can come up with something...
Mike
Mike
ARD - Stoptech is junk and will always be junk. Go buy a set and find out
Yes that GT3 setup is $2600, or you can get the Brembo with 2piece rotor which is lighter and better cooling for $3200. Stock wheels, nope dont fit. Buy some Volk TE37, lighter then stocks, perfect fitment, 1 piece forged, and a set of 18's go for $2600. You can always cut corners and find cheaper solutions.... anyone want to dive in on turn 1 at PIR against me
mkelly - Rotora uses Axxis pads. You can cross reference pagid or ferodo too. They have replacement rotors, hats, pins, pads, lines, and everything else to be sold. Though I have never seen anyone replace them. The caliper is a 6piston and the disk is a 14.1inch setup. Same size, pic is deceiving...
How many have I sold? 3 sets. How many have Rotora sold? Well they are number 2 in brake kits behind Brembo.
Correction
Who supplies the 2pc replacement?
Mine is Brembo, what happens is you buy the whole complete disc/rotor with hat, when the disc wears you just replace the disc only, disc is £250 Sterling ($500 US) and is in the Brembo Catalogue. The only thing is the Hat, I don't think these are supplied by Brembo, might be wrong! I would talk to Dan to see if he can match the 355mm Brembo (I have) up to the GT3 Caliper, I will see if I can dig up part number.
