Help opening trunk?
Old Jan 1, 2008 | 04:33 PM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
Help opening trunk?
OK, like an idiot.....thought my car was locked....so I opened the trunk....then hit the button to unlock the car but actually locked it...threw my jacket in the trunk and closed it..with my key in it.....so now I slimjimed the door....alarm goes off....but I can't open the trunk....I assume because the alarm has been set off. Any trick or emergency release to get this thing oped? I only have one key....and it's now locked in the front...do I have to wait till tomorrow and go to the dealer to buy a key and have it programed? Hoping not....
Old Jan 1, 2008 | 05:11 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
there's an emergency release tucked in front of the passenger front wheel. you will have to take the wheel off to get in there. i used a coat hanger to grab the tiny loop and pulled.
(i had to do this b/c i disconnected the battery and shut the trunk.)
- chuck
Old Jan 1, 2008 | 05:13 PM
orlando333's Avatar
orlando333 is infamous around these parts
check the fuse box
there is a little plug which you can pull to open the trunk
Old Jan 1, 2008 | 05:16 PM
CTRacer's Avatar
CTRacer is infamous around these parts
Originally Posted by orlando333
check the fuse box
correct, sort of. that's the red (+) end so you can connect jumpers to that and then ground (-) it on the door latch. After you connect this, the truck should open with power.
Old Jan 1, 2008 | 05:17 PM
Turbochris's Avatar
No, the little plug in the fuse box is to hook power to if you're battery is dead so you can power the solinoid that opens the trunk so you can get at the battery.....and I already tried it thinking maybe it would help but it didn't
Old Jan 1, 2008 | 05:20 PM
Turbochris's Avatar
Perfect......that's what I was looking for...did you have to remove the fender liner? I will go start pulling the wheel now.
Thanks!
- chuck
Old Jan 1, 2008 | 05:21 PM
Turbochris's Avatar
thanks for the help guys.........
- chuck
Old Jan 1, 2008 | 06:22 PM
Turbochris's Avatar
Got it! Thanks Chuck!
Old Jan 1, 2008 | 06:26 PM
carendt242's Avatar
excellent
the5
Oct 14, 2015 06:46 AM
bongnation
Sep 25, 2015 02:58 PM
lokmeup
Sep 9, 2015 09:24 PM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
katyrow
Sep 7, 2015 10:17 AM
