Big Brakes... Mmmmmm
Old Jan 21, 2008 | 09:03 AM
Mikelly's Avatar
The rotors and pads arrived today, So all that's left to do the swap is the pins and pad hardware, and new caliper bolts... Calling one of the vendors rigtht now to finish this up... Like to have them on this coming weekend!
Mike
Old Jan 21, 2008 | 10:39 AM
tom kerr's Avatar
Mike
good luck Mike mine also should be done by this weekend!!
Old Jan 21, 2008 | 11:34 AM
930man's Avatar
930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future
i dont know if i need brakes or just learn how to use them better
Old Jan 21, 2008 | 03:13 PM
Mikelly's Avatar
Spent some time on the phone with the guys at suncoast, and a little time with my catalog from Coleman Racing. The rotors in the pic above could be duplicated for under $600. All you need to do is send Coleman a rotor and tell them you want the new rotors to be slotted, directional vein with a diameter of 350mm (Mine the pics are) and the proper thickness (I didn't pull it, but think it's 1.35 inches).
The 350mm Rear Turbo setup is gonna run about $1600 with pads... I plan to have those on possibly by VIR as well. Had I not wanted to get away from a drilled rotor on the front, I'd have just bought UMW's brake kit and been done with it. Kevin packages the whole kit for you with everything you need for $3999.
Mike
Old Jan 21, 2008 | 03:20 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Wow those are biiiiiig. Good luck with the install Mike and most importantly let us know how they STOP.
Old Jan 21, 2008 | 08:10 PM
silvershark's Avatar
silvershark is infamous around these parts
Thumbs up More Comparisions
Stock vs GT3 upgrade
Old Jan 21, 2008 | 08:45 PM
vividracing's Avatar
post the rotor weights between the 2. Alot of people have asked me for that since it is still a 1 piece. Are they the same?
Old Feb 1, 2008 | 01:52 AM
halfday's Avatar
halfday is infamous around these parts
are those floating rotors? how much do they weigh?
Old Feb 2, 2008 | 05:27 AM
Mikelly's Avatar
Mine aren't floating and I didn't weigh them. I"m guessing they weigh about the same as the OEM steel Turbo 330MM units, maybe a hair less.
Mike
Old Feb 2, 2008 | 07:00 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Mike, that will be the main reason why your rotors are a lot cheaper. Have they just attached a Hat to the Disc? I thought you were floating!
Old Feb 2, 2008 | 01:20 PM
Mikelly's Avatar
Steve, I wasn't shooting for floating rotors. My main goal was to get away from the cheese graters... I also didn't want the noise I've heard from floating rotors. I drive my car a lot on the street.
I just bedded the brakes with Cohare in the passenger seat, and they performed well...
Mike
Old Feb 2, 2008 | 02:14 PM
Nice1, they will last longer for sure over stock. My floating rotors are noisey (when cold) once heated they are fine, no noise at all, just a lot better than solid 1 piece rotors for track work. Did you try that rear mod yet?
Old Feb 2, 2008 | 02:34 PM
Here is a quick pic of the my Brembo Floaters
Old Feb 2, 2008 | 02:49 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
These brakes feel real strong, not to mention look great!
Old Feb 2, 2008 | 02:59 PM
Just thought of something mike, bet if you get the correct hat size, you could bolt a set of these rotors you have on the rears also.
