BMC filter cleaning
Old Jan 24, 2008 | 12:47 PM
996twin_sc's Avatar
996twin_sc is infamous around these parts
BMC filter cleaning
Hey guys just wanted to hear from some of you guys on what type of cleaner you are using on your BMC filters. It just arrived today and I'm a little hesitant to use just soap. Should I purchase the cleaner from BMC or will regular soap work? Thanks.
Old Jan 24, 2008 | 01:28 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
same here....anyone?
Old Jan 24, 2008 | 01:31 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
wash with regular detergent, drip dry, put back in car
Old Jan 24, 2008 | 01:50 PM
wross996TT's Avatar
Use some diluted dish soap..drip/air dry...bingo!
Old Jan 24, 2008 | 03:02 PM
BOXER4's Avatar
BOXER4 is infamous around these parts
can't you just use the same cleaning supplies used to clean K&N filters? I have this same BMC filter and it seems to have the same makeup as a K&N....am I be wrong?.
Old Jan 24, 2008 | 03:45 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
K&N cleaner works just fine, yes. Its what I would recommend.
Old Jan 24, 2008 | 03:47 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
OK but if your going to oil it make sure you DO NOT over oil, it will blow CEL and may kill the Mass air.
Old Jan 24, 2008 | 03:50 PM
996garage's Avatar
996garage is infamous around these parts996garage is infamous around these parts
K&N cleaning kit should work. I've heard lots of guys warn against putting too much oil on the filter after cleaning it, because it can damage your MAF.
Old Jan 24, 2008 | 04:21 PM
996twin_sc's Avatar
Not going to oil it at all. So regular dishwashing detergent or laundry detergent should be just fine to clean it?
Old Jan 24, 2008 | 04:45 PM
wross996TT's Avatar
Dish, not laundry...you could use the K&N kit, but that is much more $ for dish soap
Old Jan 24, 2008 | 07:08 PM
Thanks!
Old Jan 24, 2008 | 08:46 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
I have heard to lightlly oil filter before reinstalling. You don't want to over oil but not reoiling may let some finer particles pass through the filter. May not be a big deal but the k&n aerosol oil is very easy to apply evenly and lightly. I don't like the liquid oil in the lotion type container. Sray lightly and let oil wick before reinstalling. I try to lay a paper shop towel on both sides of filter also absorb any extra before reinstalling. Little is better than more but I think some is better than none also. Anyone else?
Old Jan 25, 2008 | 09:17 AM
wross996TT's Avatar
For a new filter: Quick soak in diluted dish soap solution, rinse, then air dry....no re-oiling. You can see there is still "pink" oil left in the filter, just not as much as new. The filters are typically over-oiled from the factory as they have no idea how long it will be before they are used...and of course the oil will lose its qualities over time.
Old Jan 26, 2008 | 02:46 AM
996TTSCAB's Avatar
996TTSCAB is infamous around these parts
When I bought my BMC filter about 6 months ago I just installed it the way I received it. Instructions said nothing about washing it before the install, it looked really greasy too! I have put about 5K miles on it so far and no problems or CELL. Now I wonder if I should have washed it, wel it is too late now I guess.
Old Jan 26, 2008 | 08:05 AM
silver's Avatar
Sounds like it should be fine to do what wross suggests. I too put mine in as was. Ran it over 10,000 miles with no issues. It has been cleaned once since then. I would sugggest cleaning the maf with the proper cleaner. I was surprized that it did smooth out the idle a bit. If done correclty it cant hurt. These cars are amazing if maintained properly.
HIGHcard
Sep 24, 2015 08:09 PM
sparks
Sep 8, 2015 03:03 PM
shifter_
Sep 8, 2015 12:07 PM
Weebs
Sep 7, 2015 11:42 AM
