psm abs lights- again...
Old Feb 8, 2008 | 05:57 AM
tjj7ff's Avatar
tjj7ff is infamous around these parts
Originally Posted by smistry007
you might be on to something- I've noticed that it does seem to be associated with stop and go traffic- probably when the fan comes on and is never there late night when it's really cold.
I'll get a battery charger and try it myself and report back.
Thanks for such wonderful insight!
Sameer
You want to make sure that you bypass the alternator with battery charger otherwise you will not see any differience.
Old Feb 8, 2008 | 10:53 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
do you mean disconnect the alternator? where would I attach the jumper cables?
also, when it happens, would turning off all other electric accessories temporarily solve the problem. conversely, when the psm/ abs is functioning fine, would turning on all other electrical accessories induce the problem?
Sameer
Old Feb 8, 2008 | 12:32 PM
tjj7ff's Avatar
Sameer
I just spoke to the Porsche mechanic that worked on my car. He used a load tester to determine the problem, not a battery tester like I thought...sorry about the mis information. He ran the car at idle and turned on the A/C unit causing the condenser and evaporator fans to come on. As the engine warmed up the the front and rear engine fans also came on. He took amperage readings before, during and after when the A/C was turned on and then off. The alternator dropped in output amperate to 63 when all of the systems were running. This caused the engine RPMs to get worse as the 996TT electrical system does not favor the engine over other systems such as the PSM and ABS. Evidently the newer models shut down other systems in keeping the engine running. He said the amperage output should have been twice the amount that showed on the load tester. Sorry for the confusion.
Old Feb 8, 2008 | 09:58 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
TJJ: Thankx....good info. I know there are a lot of guys being troubled by the PSM/ABS issue...there's another thread in here going on about the same issues. Most of the time I turn the car off and back on and it clears...but your info about the alternator is worth remembering. What's the correct Amp output rate when the systems are all running?
Old Feb 9, 2008 | 06:27 PM
tjj7ff's Avatar
I'll have to check on Monday with the Porsche mechanic as I don't know what the specifications are for the alternator. When we were talking to another last week he the 63 amp output was half what it should have been with a full load. Perhaps someone else on the board knows?
Bmw M3 Guy
Feb 21, 2018 09:29 AM
randalldahme
Feb 19, 2016 03:56 PM
ophtho
Sep 18, 2015 03:00 PM
JWrightPNH
Sep 17, 2015 01:42 PM
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
