Simple and Easy 996 TT OEM SEAT Mod
Old Mar 5, 2008 | 11:54 AM
  #61
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
for me this is the difference between keeping the car for the next 5 years or not, I am 6`6 by the way and about 225 lbs, I remain amazed by the improvement and additional connectivity with the car it gives
Old Mar 5, 2008 | 12:28 PM
  #62
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
I did this as well to my stock "standard" seats and used some foam i found in the garage. I think its old mattress foam. It is an improvement for sure and i like the better side support. On the other hand, i still think these seats suck and if i was going to keep the car forever, i'd upgrade. Great post and thanks!
Old Mar 6, 2008 | 12:18 AM
  #63
twin snail's Avatar
twin snail is infamous around these parts
you are pretty sharp; I really miss the siting inside the car/between the fenders feel of the 911; I hate sitting on the seat; I realize that Stuttgart needed to put the CPU somewhere but why under the drivers seat?! I had posted a seat lowering question in Rennlist and recv'd a brilliant suggestion to lower the car.... You need to feel the car with your rear end down and your back straight to drive well
Old Mar 6, 2008 | 01:13 AM
  #64
Turbo Fanatic's Avatar
Thanks for the sentiment, but no need need to apologize. it was my decision to try it. Now I feel a poke in my spine all the time. It's fun doing projects. Sucks having to undo them.
Originally Posted by Alpha
Ari -- The sports seats have much larger side bolsters than the standard seats -- so you already have much better lateral support in stock configuration. How thick was your stock foam? Mine was at least and inch and a half thick lower down. Maybe the sport seats have thinner OEM foam?
If you are not feeling any improvement, plus you are feeling the frame and cross bars, I would go back to stock. Sorry you spent time on this mod and came away empty handed for your troubles. It took me a bit of time to make my seat comfortable for me.
Old Mar 6, 2008 | 11:43 AM
  #65
RCH's Avatar
RCH
Ari you took out the metal ringlets right ? fwiw as I have no foam at all you can also change the location of all the little air bags which blow up for seat support, they are on a vertical rack
Old May 17, 2011 | 10:01 AM
  #66
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i know this is a very old theread but i expect a lot of members have never seen it and it seems to be well worth the bump
can anyone who did this mod comment on whether they are still happy with it ?
Old May 17, 2011 | 12:01 PM
  #67
turbo_banker's Avatar
turbo_banker is infamous around these parts
wow this sounds great, i'm going to give it a shot.
Old May 17, 2011 | 12:13 PM
  #68
hmmm, just checked it out, seems all the seat heating kit is inside the foam? is that not problematic...
Old May 17, 2011 | 12:42 PM
  #69
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
I'm still happy with my result
Old May 17, 2011 | 12:52 PM
  #70
I hated it and took it out. Even had a professional upholstery shop make me a thinner foam insert. A few pressure points where the springs were digging into my back made this mod totally painful and not worth it.
Old Jul 3, 2022 | 03:55 AM
  #71
Rapid-911's Avatar
Rapid-911 is infamous around these parts
Going to give this a try, I hate my standard seats feels like sofa less supportive than my “normal” commute car.
Seeing this is old, any other mods known? Was going to do buckets but like option of rear seats with standard.
Old Dec 17, 2022 | 06:40 PM
  #72
mffarrell's Avatar
mffarrell is infamous around these parts
I know this is a VERY old thread, but I can’t get my center seat cushion to disengage the three white tabs from the metal cross bar. If I put any more upward force something is going to break!
when I lift up on the cushion, the tabs barely move from the cross bar. I tried pushing a screwdriver downward on the crossbar, per the workshop manual, but it barely moves. It looks like there is a piece of styrofoam blocking the tabs from clearing the crossbar.
Thoughts?
Thanks!
Old Dec 19, 2022 | 12:47 PM
  #73
mffarrell's Avatar
tropicatango
Jun 8, 2025 01:00 PM
tropicatango
Dec 4, 2015 02:45 PM
dc3843
Aug 22, 2015 09:33 AM
TrackOne
Aug 20, 2015 12:56 PM
pwdrhound
Aug 20, 2015 05:54 AM
