Carbonetic Triple Clutch
#46
I have been talking to a lot of tuners and Porsche techs and we have concluded that the best way to get a triple clutch pedal to engage during the middle of the pedal travel and not the last 1 inch is to alter the slave cylinder. By fabricating a bracket that will position the slave cylinder 1 to 2 inches away from the original position will give the desired affect I want.
The other idea is to add an adjustable master clutch cylinder. I have this one already in motion. The only problem with this method is that it will only lower the pedal which is great, but I wanted a little more.
I would like to keep the two pedals at equal height and not alter the pedal travel, but alter where the clutch actually engages. The former should do this.
What do you guys think?
Also, the clutch is starting to feel better and I think it may be a keeper. Jury is still out since I only have 130 miles on it and the manyfacture says break in is 800 miles.
#47
My biggest desire would be to have a full range of clutch motion to control the clutch, The spring remove helped mine quite a bit and it's free, it brought the pedal and engagement down a bit, not at the middle, but where the middle used to be if that made any sense. It make the pedal a bit more firm, but with a triple it's like already a bit softer than stock. Let me know if you find a better solution that works.
#48
I just got mine back...clutch does not engage until last couple inches of travel. Stalled twice on the way home.
However, Tommy says that as clutch is broken in it will start grabbing more towards the middle of the clutch travel range. When it grabs, it GRABS! And it is no heavier or louder than my old Sachs set up.
Finally, Tommy gave me an absolutely FANTASTIC deal. Of course I promised to give him a deserving write up once I get the clutch broken in (after about 500 miles or so).
#49
I _hate_ the hydraulic assist and that's in combination with these "race" style clutches it makes for an unpleasant driving experience with the high hp kits. Depending upon what you have in there I'd suggest doing the GT2/Slave/Master conversion and dump the hyraulic assist crap. Yes the pedal will be stiffer. Somewhere around the GT2/GT3 and perhaps a bit stiffer (this is dependant upon the kit you put in) but the fact that it no longer engages right at the very top and can be modulated/felt makes me much more happy.
#50
So you are saying just order a GT2 Slave and clutch Master cyclinder and it will help? Do you have the part numbers?
#51
#52
#54
Moving the slave 1" away from the clutch would not be a simple job without removing the tranny. If you didn't get it right, out with the tranny again. I'm looking forward to hearing about someone else doing it first.
#55
That is why they quoted me $1200
#60
No, my is still stock.
