White Smoke!
Old Mar 16, 2008 | 03:33 PM
Addicted's Avatar
Addicted is infamous around these parts
White Smoke!
I got a 03 TT w/ 37k miles. A month or so ago it started smoking, white smoke, on start up. Doesn't smoke after warm up. Not horrible, but not right either. About 2 weeks ago a CEL came on and I took it to the dealer. Dealer said I needed to change spark plugs out. Dealer said smoke was from the bad plugs, and TT were known for smoking more than most. I had local shop change out spark plugs, change oil, change the Polyrib belt, and give it a good once over on Friday. On cold start the car smokes even worse than before. It is almost unbearable the smoke. Last for about a solid minute or so until the engine is warm and goes away. Embarrassing for such a nice car to smoke like a 1960 Ford on its last leg, start up. Any ideas what is causing this?
What says the group? Thanks in advance.
Old Mar 16, 2008 | 04:12 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
What does it smell like? Any chance it is oil seeping past valves while the car sits? Another possibility might be excessive water condensation somewhere in the exhaust system.
Sorry I can't be of more help.
Old Mar 16, 2008 | 04:15 PM
Addicted's Avatar
Smells like that smell you get after shooting fireworks. That's about the best I can describe it. Hope that helps.
Old Mar 16, 2008 | 04:54 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Maybe time to service your injectors. Sounds like its running lean on start up. Maybe some fuel injector cleaner will help.
S
Old Mar 16, 2008 | 05:12 PM
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
to be 100% honest, once i went with a new exhaust + turbos... my car just doesnt smoke on a cold morning anymore... i wonder what it has to do with... i know in the RX-7, it used to smoke a little when you first started off cause it burned the excess oil in the engine.
Old Mar 16, 2008 | 05:20 PM
Addicted's Avatar
Yea, I use to have a RX-7, but this is a lot more smoke than that. This fills my garage and would choke you. Clears up after warm up though.
Can you buy just the fuel injector cleaner you add to the gas at an auto parts store, or is that a bad idea?
Old Mar 16, 2008 | 05:23 PM
SOunds like unburned oil to me...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 16, 2008 | 06:06 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
oil is blue fuel is blk water is white
Old Mar 16, 2008 | 06:24 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
Sent you a PM
Old Mar 16, 2008 | 07:38 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
From what I have read on these forums, it is normal. Apparently it is from oil that gets stuck in the combustion chamber. This happens because of the horizontally opposed setup. It happens on my car about once every 6 startups, but only when completely cold.
Old Mar 16, 2008 | 07:51 PM
torresmd's Avatar
torresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond reputetorresmd has a reputation beyond repute
Also happens to me. Always cold and every so often, last only a few seconds and then gone.
Old Mar 16, 2008 | 08:43 PM
unvmy996's Avatar
its normal i asked Tod k and thats what he told me also.
Velgen
Sep 10, 2015 01:02 PM
sparks
Sep 8, 2015 03:03 PM
JSF721
Detailing
Sep 8, 2015 07:57 AM
