Leaking F Hose affecting performance
Old Mar 26, 2008 | 04:01 PM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
I am now boosting 1.1 bar and was stumbling a little at 5200rpm in 2nd. The stumbling was inconsistant in all gears so I decided to pressure test my boost system.At about 18psi everything held except I could hear air escaping up on top. Got the soapy water out and confirmed that I was leaking pretty good at BOTH the inlets to the DV`s from the f Hose. I am waiting for a silicone one. Any one else have this happen to them and what was your performance loss because of this? thanks
Old Mar 26, 2008 | 05:37 PM
mikerosi's Avatar
Nobody??
Old Mar 26, 2008 | 05:42 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I had the same thing happen, your not going to notice much of a performance loss with that small of a leak.
Old Mar 26, 2008 | 06:54 PM
sharkster's Avatar
has happened before... I splite one on my own car and I remember at least a couple more cases.
Old Mar 26, 2008 | 07:44 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
I replaced my f-hose, its not surprising, they dry out as they age.
Old Mar 26, 2008 | 08:01 PM
PorschePhd's Avatar
They will also split right down the half that they are formed from the mold. They start as a little leak and then will rip open.
Old Mar 26, 2008 | 08:23 PM
mikerosi's Avatar
Hey thanks Alex and Stephen, I guess it happens. The silicone one i think should be better. Would this cause any sputtering on boost?? My plugs are new BTW
Old Mar 26, 2008 | 08:25 PM
PorschePhd's Avatar
Well it could if the plugs are weak. But not normally. The silicone one is solid. You will not havbe this issue again. How many miles on your car and mods?
kilrgt's Avatar
Its very possible, as you know 9 times out of 10 its plugs or the mass air.
tropicatango
Jun 8, 2025 01:00 PM
turkish1
Nov 11, 2015 09:01 PM
magoochi
Aug 23, 2015 05:54 PM
ECS Tuning - VW
Aug 19, 2015 10:43 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
